Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
#2116
Well that is certainly what I am hoping. I just got this information from the manual on page 15 where it shows the "A" and "B" configurations
#2118
Bummer.. getting it turned around is no big deal but I just hope I can shim it correctly. I've never done that before
#2120
I have some PL ones so they should have some. I think there's others that will work, but I'm not sure of the offset variances between different Mfg.'s, like say, Losi 22-4 and ZX6
#2121
Schumacher wheels are softer and gain grip over the Kyosho wheels, my choice on wet astro.
#2123
Got it all swapped sounded a little loud but we will se how they are when I'm actually driving
#2124
So I was driving the car last night and mind you this is my first 4wd. But it was kind of hard to drive. The car was really loose coming into corners. Like if I let of or coasted into a corner it would sometime completely spin around the rear wheels. do you just have to stay on the gas a little bit to round corners nicely?
#2126
Guys are you running gear difs or ball? If ball the tightness of each dif is very important. Also more aggressive front tires than rear can effect the rear of the car as does the sway bar. What type of surface are you on?
#2127
I have ball diffs. And it is true my front tires had more tread than my rear. And always find the "what kind of surface are you on" question hard to answer since it's relative. But I am on clay, usually watered and decent traction. Don't know if I would classify it as high traction.. but
#2128
I run gear diffs (8-500-8), front tires wear more then rears, med/high bite clay running treaded tires. I just put a thinner sway bar up front (1.0) 1.3 in rear. I got more steering w/ thinner front sway bar but rear end still wants to come around off power when turning off of fast straight or fast sweeper. Thank you for your time/help likea45
#2129
Going in order.
What is the tire of choice at your track? That will give me some indication of what kind of surface it is. While it may seem subjective, it's relative to how you set the car up. I would try running your rear dif a little bit looser and swap your front and rear sway bar.
On treads I found that 500k was just too stiff and anything above 7k in the rear was not letting the car rotate as it should. I had this issue initially at 10-500-10. I tried swapping the front and rear sway bar and then found the magic number (for me any way) which was 7-300-5. Give it a whirl one of the two tracks I run at regularly sounds like the surface you are on.
