Tekno ET48 Thread >
Tekno ET48 Thread
Like Tree38Likes
Tekno ET48 Thread
Old 08-03-2014 | 03:15 PM
  #3196
Originally Posted by Vegetable
Hi
I'm new here to this forum bit have just picked up an et48 and it's a beast. But on my first run out I've cracked a front drive shaft at the pin end that goes into the diff and the pin has come loose. Is this a known problem with these drive shafts. This is not the centre front drive shaft but the steel one going to the wheel.
I saw the same thing today, a new racer with the same problem as you but the two front driveshafts lost their pins almost at the same time! He had replacement drive shaft but still doesn't understand what the cause is. I have mine since march, practice a lot and race and no problem at all for me. Maybe a bad batch of driveshaft.
tntpower is offline
Old 08-03-2014 | 11:22 PM
  #3197
I just wanted to add that this weekend was the first run on my NT48 and I drove it very hard and I just finished going through it getting it ready for next weekend and both front axles are still good to go, no cracks in these shafts. Hopefully it was indeed just a bad batch somehow.
adubaz7 is offline
Old 08-03-2014 | 11:48 PM
  #3198
Registered User
Well I am going to try this setup when I go do. A test and tune on the weekend with diff oil going 10k in the front 10k in the centre and, 10k in the rear Intreated too see what it does with the shock oil being 35 front and. 40 in the rear
TheMuffinman is offline
Old 08-04-2014 | 05:15 PM
  #3199
R/C Tech Elite Member
I finally changed mine to 10/15/5 a week or so ago. I've only had it out once since then and the track was very dry with loose dirt and low traction. Sure seemed like I had more steering and tighter turning radius than the last time I ran it on similar track conditions though.
I'm hoping to make it out for a little practice Thursday night and then do our local club race Saturday. We'll see how it feels on a better prepped track.
iScream is offline
Old 08-04-2014 | 05:30 PM
  #3200
Registered User
if mine don't work on the weekend I m going to drop the rear diffoil to 5k try droping yours center diff t 1k
Old 08-05-2014 | 07:39 AM
  #3201
One Mile Up's Avatar
Interesting... this is usually how my local track conditions are. I am running stock right now (20/20/10). I really want to rip the diffs out already and change out the oil weight to 10/15/5 since it seems this is the most common set-up thus far.
What are people generally using for springs/oil in their shocks? I am running stock set-up here too buy would like to experiment!
One Mile Up is offline
Old 08-05-2014 | 04:35 PM
  #3202
Registered User
I am charging to 10/10/5 with shock oil at 40 in the front and 35 in the rear
Old 08-06-2014 | 08:43 AM
  #3203
Mizchief's Avatar
I'm running either 10/15/5 or 20/15/5 can't remember, but really looking for more slow corner rotation and/or steering coming out of the corner. I'm really having to throw the rear end into the turn coming to get it to come around. I'm tempted to try 3 in the rear but seems really low for such big tires.
Mizchief is offline
Old 08-06-2014 | 03:40 PM
  #3204
rcboy1's Avatar
I am currently using 10/10/5 diff fluid and 47.5-37.5 (stock pistons) shock fluid and It works very well.
Mizchief, if you need both exit and slow speed steering a diff oil change may not be what you need. Try moving your front inner link up on the tower and see if that helps at all for you.
rcboy1 is offline
Old 08-06-2014 | 06:47 PM
  #3205
Registered User
hey guys I just wanted to know has any one run these in there et48
http://hobbyking.com.au/hobbyking/st...case_Pack.html if so how did they go and did they fit
Old 08-06-2014 | 07:05 PM
  #3206
Jpm1's Avatar
There very long, doubt they'd fit.
Jpm1 is offline
Old 08-06-2014 | 07:13 PM
  #3207
Registered User
thanks jp
Old 08-06-2014 | 07:54 PM
  #3208
Jpm1's Avatar
thanks jp
The battery tray is 148mm x50mm, so if your going for something that is not Roar standard then there the sizes you need.
Justin
Jpm1 is offline
Old 08-06-2014 | 07:55 PM
  #3209
Registered User
thank you Justin yeah the wife has crack the whip she told me I had found lipos cheap lol
Old 08-06-2014 | 08:43 PM
  #3210
Jpm1's Avatar
I understand that lol but there is probably better value packs around then those, they are $60 SMC 5000's are only $80 in oz and a lot better packs!
Jpm1 is offline
