Hobby Pro USA PR S1 2wd Buggy ALL NEW
#2207
This car is so crazy good in rear motor outdoors. I can't believe how good it is. I thought it was decent in MM but found B5M to handle better indoor for my taste, the PRS 1 went on the shelf. Dusted it off and converted it to RM just for kicks and all I can say is wow. It's outperforming any 2wd buggy ever driven outdoors. The steering capabilities are amazing. Im back in love with this buggy! if you plan to race outdoors at all this car is a serious advantage.
#2208
#2209
opps , not sure how this happened but I'm glad I took my cover of to clean my buggy..
#2210
#2211
anyone know where I can get part # 80400016 M2.5x4mm screws that hold the hing pins in on the arms.. I'm playing around and I need some for my project...
#2213
Hey all
I've got the SC version of this car and yes ... the spur gear kinda sucks with the limited height of the inset for the pads. Have any of you needed to modify the AE spur gears to get them to fit? Seems like the top shaft is a little thicker than hole in the JC spur that I have.
Cheers
Cheers
#2214
Hey all
Cheers
Cheers
#2216
I only run the PR racing spurs and have never had a problem until just this one time...
#2217
#2218
Great day of racing today with my Hobby Pro buggy testing out my new esc... I got TQ and the win in mod expert buggy...
#2219
Prs1 v2 mid motor config
Shorty lipo in front, esc in back
class: 17.5 stock buggy d3.5 17.5
My problem is this... Our track is indoor blue groove that they spray a military grade acrylic glue on top of the blue groove. I get awesome traction using barcodes in gold compound but they only last 2 1/2 qualifiers. They hook up great till the center of the tire looses its tread, then its all over and my lap times go up by 1.4 seconds... I'm using Aka red premoulded foams for my inserts. Any input would be greatly appreciated. I've tried harder compounds only to sacrifice traction due to the hard rubber. Could it be that i need my battery in the back and my esc up front? Maybe excessive wheel spin is causing my tires to wear prematurely?!? Anyone? @ Thanks in advance.
MIKE
#2220
That's about right. Tires are made to offer maximum grip but the higher the grip level, the quicker the degradation. Serious top level racers tend to destroy a set per run so they go through 2 qualy runs and the main, each with new tires.
I've had days where I've gone through my rubber like that, but generally tires last me 2 qualifying rounds and I always run a new set for the main. Panther is the only company who's tires are actual rubber and they tend to last longer. Most others are an artificial rubber composition that's engineered to maximize grip but sacrifice durability to do so.
