TLR 8IGHT E 3.0 THREAD
#1186
Double post, ignore.
#1187
Good luck, the best thing to do is to pick and choose different things to try from different setup sheets to personalize it to what you need.
#1192
R/C Tech Elite Member
Can't say the track I run on is really loamy, but is big outdoor with changing conditions. I run CSI blues with 30f/27.5r and my buggy rocks. Took fourth place in expert this weekend and that is the best I have done and is my second race with this buggy. I will note to watch your center diff, I (yes, my fault) didn't tighten the screws so as to not overdo it and it leaked on me. Refilled, retightened and no problems. Btw, I'm running kit diff setup still.
#1193
Finally got a JConcepts Silencer painted up for the 8ight 3.0. We tried something on the windows, and that turned out pretty bad. I can't say that I was a fan of the stock body, but I sure did miss it being precut and ready to go.
I'm liking the car so far. I'm basically on the stock setup with 5/5/5 and the thinnest front sway bar.
I'm not too sure on what to do regarding shock oil. I've got the stock springs and stock pistons. I run on a smaller indoor track with smaller. 50* or so temperature wise.
Being an old Associated owner, I really like a good amount of droop with a really good amount of dampening in the shocks. Could someone suggest a droop/shock oil setup that works with the kit springs and pistons?
It will be much appreciated.
#1195
#1196
What KV should I run with this buggy? Im gonna buy Tekin, RX8 esc, thinking a 2050 T8 Gen 2 motor? Any suggestions?
#1197
around 1900kv is the most common
#1198
#1199
What kind of track do you run on? Im using indoor med size, Tekin t8i 1950 with 15/45. Plenty of power, super smooth and quiet. After 10 min main temps were at 165f. Couldnt be happier with this Tekin setup.
#1200
Anyone know if the steering rack set (TLR244005) for the 8IGHT 3.0 will fit in my 8IGHT-E 2.0 buggy ?
Some people call it an "ackerman" or "linkage".
I like how this particular part for the 3.0 pivots on bearings, and would love to use it as an upgrade for my 2.0 .
Thanks for any info.
