TLR 8IGHT E 3.0 THREAD >
Like Tree2Likes
Old 12-22-2013 | 07:54 AM
  #1141
Kaw1000's Avatar
Thank ya sir!
Kaw1000 is offline
Old 12-22-2013 | 01:20 PM
  #1142
ta_man's Avatar
Originally Posted by dynamiteracer
You should be able to set it a little looser with the metal gear.
You can....but I wouldn't (and I don't).
ta_man is offline
Old 12-26-2013 | 08:35 AM
  #1143
sanny632's Avatar
Is there a page that lists the parts shared between the 2.0 and 3.0? I have a e 2.0 w a lot of parts but I'm selling it for a 3.0!not shire if I should keep these parts. Thanks guys
sanny632 is offline
Old 12-26-2013 | 09:05 AM
  #1144
We never put together any list of this nature but you could take the parts list for both and compare them. The primary things that are the same would be diff parts.
hacker07 is offline
Old 12-26-2013 | 11:48 AM
  #1145
sanny632's Avatar
Oh ok thanks a arms different? Spindles and hub carriers
sanny632 is offline
Old 12-26-2013 | 12:08 PM
  #1146
Rear hub carriers are the same, arms and spindles and front carriers are different. The rear arms might be the same, front are def different.
hacker07 is offline
Old 12-26-2013 | 10:11 PM
  #1147
sanny632's Avatar
thank you very much
sanny632 is offline
Old 12-27-2013 | 11:08 AM
  #1148
sanny632's Avatar
I run your awesome dunford setup on my scte2.0
. Is there a end all be all set up for the 3.0 to start from? Also I'll be indoor clay med bite (lesiure hours) until summer then outdoor low bite loamy
sanny632 is offline
Old 12-27-2013 | 10:16 PM
  #1149
My 2.0 e has a wrecked front end and I need new shocks and possibly a new shock tower. I was wondering if the front and rear shocks and shocktowers of the 3.0 are able to be fit on the 2.0?
nathant123 is offline
Old 12-28-2013 | 08:18 AM
  #1150
yes they will
dynamiteracer is offline
Old 12-29-2013 | 06:25 AM
  #1151
wheelman17's Avatar
will the 2.0 aluminum servo saver arm fit on the 3.0e
wheelman17 is offline
Old 12-29-2013 | 12:23 PM
  #1152
TimMo846's Avatar
yes it will, and highly suggest buying it and replacing it asap. The plastic one will break, if it hasn't already on you.
TimMo846 is offline
Old 12-30-2013 | 07:32 AM
  #1153
slakr's Avatar
What is the part number for the metal spur gear?
slakr is offline
Old 12-30-2013 | 10:09 AM
  #1154
dtr's Avatar
dtr
LOSA3552 is the 45T spur; there are 46, 47, 48 & 50 as well but those might be too big.
dtr is offline
Old 12-30-2013 | 10:33 AM
  #1155
slakr's Avatar
Thanks DTR!
One more quick question (just so I don't screw it up out of the box... LOL):
Can someone recommend starting pinion with a Tekin T8 2050kV motor?
I only race outside, and mostly on medium to large (not huge) sized tracks.
Thanks in advance.
slakr is offline
