TLR 8IGHT E 3.0 THREAD >
Like Tree2Likes
Old 02-28-2015 | 04:30 PM
  #2971
Originally Posted by KOULLIT
Hi RandyJones,
Maybe your are a great driver too !
Of course you can run with the short ackerman plate without any issue, but you may have an issue if you hit something, then if you need your servo saver to do its job !
Bye !
Not sure what your issue is but, I don't race. My 14 year old son races and he wrecks. We've had zero issues with it. And we run servo saver basically locked in his truck also.
RandyJones is offline
Old 03-01-2015 | 09:57 AM
  #2972
DiaRh34's Avatar
Will 3.0 e bodies fit a 2.0 e?
DiaRh34 is offline
Old 03-01-2015 | 10:14 AM
  #2973
How many of you drill vent holes in your body? Where is the best spot?
Hinch45 is offline
Old 03-01-2015 | 12:11 PM
  #2974
muggy427's Avatar
No not at all
muggy427 is offline
Old 03-01-2015 | 05:28 PM
  #2975
DiaRh34's Avatar
Originally Posted by muggy427
No not at all
DiaRh34 is offline
Old 03-01-2015 | 06:36 PM
  #2976
Brian C.'s Avatar
I think the nitro body fits it though...
Brian C. is offline
Old 03-03-2015 | 03:36 AM
  #2977
Tried scanning this post but I'm a bit confused on what body I need for a conversion...
I have a Losi 8ight 3.0 nitro and a conversion kit and I stupidly thought hey I'll just get the e 3.0 body however it appears that body is quite a bit slimmer so doesn't cover the plastic sides.
It seems people have been using a Proline Bulldog but I can only find this for a 8ight-e 2.0 body. Can anyone confirm if this will fit and also what other body options that would fit? The proline seems to be out of stock pretty much everywhere I look at least in the UK
evilhomer80 is offline
Old 03-03-2015 | 07:41 AM
  #2978
Casper's Avatar
The 3.0-E specific chassis is more narrow than the nitro chassis so -E specific bodies will also be more narrow. Any nitro or 2.0 body should fit just fine as the body will be wider to fit the nitro chassis. Does that help?
Casper is offline
Old 03-03-2015 | 10:36 AM
  #2979
KOULLIT's Avatar
Hi RandyJones,
It's not "my" issue". You are right, we can run the car like this.
But, I just wanted to show what is the problem with the short ackerman plate.
It's the same for every users. Everything is on the pictures, I'm sorry, maybe because of my poor English, but I can't explain it better.
Now, if nobody has ever broke any servo, so there's not any problem.
Bye !
KOULLIT is offline
Old 03-03-2015 | 01:42 PM
  #2980
Brian C.'s Avatar
Actually the chassis isn't narrow it the same with if not a mil or two wider, they made the side guards super narrow thats all
Brian C. is offline
Old 03-03-2015 | 04:28 PM
  #2981
i know i had seen it mentioned before, but i dont remember what the exact issue was....
There isnt enough rebound on my front end.
For those that had a similar issue,what was the fix??
NickTheGreek is offline
Old 03-03-2015 | 04:45 PM
  #2982
Dan.J's Avatar
Probably the camber rods, check all the ends on all rods and make sure the balls all move freely, if any are tight give the end a squeeze with some pliers and they will loosen up. If that isnt the issue look for bent hinge pins or possibly shock shafts. Just got to start looking at things until you find the problem area.
Dan.J is offline
Old 03-04-2015 | 05:21 AM
  #2983
mxnickj's Avatar
I know I just built my kit and without the shocks on, the front AND rear arms won't even drop on their own. My camber rod ends were REALLY REALLY tight. I couldn't get mine to loosen up by squeezing them. Any other ideas?
mxnickj is offline
Old 03-04-2015 | 05:58 AM
  #2984
losialltheway1's Avatar
I had the exact same issue. It does have a little to do with the ball cups, but mainly with the hinge pins. I was told by a pro that when we insert the droop screws it tightens up the inner holes on the a arms. Ream or drill out the holes for the inner hinge pins slightly on all 4 arms. That's what fixed it for me. Let me know how it works out!
losialltheway1 is offline
Old 03-04-2015 | 02:48 PM
  #2985
Casper's Avatar
I consider the side guards part of the chassis and the body will not fit assuming you are running them.
Casper is offline
