TLR 8IGHT E 3.0 THREAD >
Like Tree2Likes
Old 03-03-2014 | 09:34 PM
  #1486
Stock gearing for the car using 1900kv tekin?? Everyone having good results with plastic spurs? Gearing the car taller make the motor temps go up I assume? Is there a need for gearing change or can you change the power curve with the hotwire?
I'm new to electric....we have a track here that is HUGE and I gear my nitro up to let it stretch it's legs and it works well....I assume a coue gearing options in the box can't hurt, but we all know what assuming does....I just want to make sure I stock the right stuff....ordering next week
motoclay is offline
Old 03-03-2014 | 11:56 PM
  #1487
Salkin's Avatar
I use the E 3.0 setup sheets on TLRacing.com, identify which track they apply for, go to youtube and find a clip from that track, and indentify tracks that are similar to the ones I'm driving on. Then I copy that specific setup and go from there.
For example, the setup sheet that Dakotah Phend posted here applies for a track that is similar to the one I'm driving on mostly, so i copy this setup.
Off course different driving styles influences on which setup is right for you, but as a non pro driver, a good proven setup is better than leaving you self to your own devices.
You ask about gearing, pinions etc. That info are also on the TLR setup sheets.
I use the 45T metal spur gear. I provides unquestionable duarbility. Some have no problems with the plastic ones. Go metal if you want to be safe.
And on the "non serious" side of things, I like the raw metallic sound of a metal spur gear. It gives the car its own "sound", as opposed to nitro cars :-)
Salkin is offline
Old 03-04-2014 | 04:55 AM
  #1488
Speed Freak RC's Avatar
If you pick up 14-16 tooth pinion gears you will be set for pretty much any track with a 1900kv on 4S.
Speed Freak RC is offline
Old 03-04-2014 | 05:45 AM
  #1489
Salkin's Avatar
+1
I run the 45T metal spur gear and run with 14T pinion and gear up to 15T if needed.
Salkin is offline
Old 03-04-2014 | 06:32 AM
  #1490
The metal spur gear is extra noisy right? I have my doubts about the plastic gear but I don't want it to sound like a janky ass pick up on a dirt road....
motoclay is offline
Old 03-04-2014 | 07:24 AM
  #1491
Salkin's Avatar
Yes, the metal spur gear makes extra noise. But I like my car to have a "noise" or "sound".
Salkin is offline
Old 03-04-2014 | 08:56 AM
  #1492
offr0aden's Avatar
I run a fairly large track that has lots of technical areas and jumps. In my nitro converted 3.0 I'm running a 17t pinion on my tekin 1900kv with a 45t spur (metal). My motor temps at maybe 100* in ten minutes. The battery is never warm. I have plenty of power in the infield and can run with the 2650kv motors down the straight.
I tried running a 13 and a 15t on the same track and after 5 minutes the battery was really hot to touch and the motor was also hot - when I geared up everything balanced at 16t and 17t pinion.
My thought is the motor was more consistently at full RPM and the battery was discharging at its max rate through the ESC. With the higher tooth pinion the torque was awesome and the temps dropped to almost nothing.
offr0aden is offline
Old 03-04-2014 | 10:14 AM
  #1493
Casper's Avatar
Yes you have to adjust gearing to the track some. Running at red line is not good on any of the system.
Casper is offline
Old 03-04-2014 | 01:30 PM
  #1494
TY@TEAMTEKIN's Avatar
Team Tekin
I'm running 14/43 and it is perfect just about everywhere I've been. Plastic spur has been good to me, love how quiet it is.
TY@TEAMTEKIN is offline
Old 03-04-2014 | 10:28 PM
  #1495
How does this car drive compared to the kyosho. I have the kyosho and just winding if it is worth switching. I like the kyosho just parts are too expensive.
masin14 is offline
Old 03-05-2014 | 12:13 AM
  #1496
Salkin's Avatar
That's the kind of question you will never find a straight answer for
In this thread, people will say yes, on the Kyosho thread they will say no.
You can find some people who came from Kyosho to TLR and liked it or disliked it. And vice versa.
You probably need to try for your self to know.
Salkin is offline
Old 03-05-2014 | 10:20 AM
  #1497
OK thanks I will probably order it this week.
masin14 is offline
Old 03-05-2014 | 12:30 PM
  #1498
rcq
Hello
I have get good price for this buggy so I have to order very quickly this model. Can you surgest what extra parts I have to order to have it neare the hand.
THe most interesting what diff and shock oils, swaybars, springs and shochs pistons need to have for first try .
rcq is offline
Old 03-05-2014 | 02:26 PM
  #1499
Casper's Avatar
I can tell you the 8ight-E is the current national championship car. Second at the Dirt Nitro Challenge. So very podium capable. Parts are a lot cheaper but best part is you should not need any/many as the car is VERY durable.
Casper is offline
Old 03-06-2014 | 11:27 AM
  #1500
sunco1's Avatar
I've had my 8ight e 3.0 almost since it came out and I never noticed my motor mount plate was machined wrong. I've only run it a few times though. I thought it was just a wacky design. It has a screw hole on the other side so the slot for tightening the pinion was facing my battery. Horizon is sending me a new one
sunco1 is offline
