X-Factory X-6 Cubed
#1126
The box setup is arms and hubs forward. So moving either back will extend the wheelbase. Obviously moving both all the way back will extend it the most.
I forgot above when I mentioned I was running the box setup mostly that I had gone with mid/mid for the rear hubs and arms during the build because I didn't like how much my squared always seemed to push. I think this might be why my rear end is a bit squirrely. I'm going to try moving the hubs forward first and see how it improves then try both forward if necessary.
I think going mid/mid just took a bit too much weight off the rear. Kind of wondering if moving the weight with hub/arm adjustments will require a slight change in rear spring stiffness.
#1127
Both, it just depends on the feel you are looking for
#1128
Mark,
Do you feel there's any difference in moving the hubs versus moving the arms?
#1131
Is it because the toe angle has a magnifying aspect on the adjustment at the arm?
There is a larger range of adjustment possible at the hubs I think.... from a pure shim standpoint.
#1132
Trader Rating: 27 (100%+)
#1134
I have no idea. Only run mod personally
#1135
Awesome thats pretty close to what i was thinking. How much timing are you running? Anyone want to share some ideas on elimnating a mid corner push? Notable items: im only running 1* antisquat with a 1mm shim in front and none out back. 2mm on inner camberlinks front and rear middle hole in the rear with c hubs. Personally im thinking of going to the 2mm front antisquat shim and reshimming the rear to go back to 1* deg but with a higher roll center.
#1136
#1139
I run 32/72 with my Novak 17.5
My track is a tight small indoor track though.
On another note, I had to change from a 69 to 72 because the motor wouldn't go back far enough with the 29 pinion I was going to run.
#1140
From what I've seen, Trinity's do well with low gearing. I know the Ballistic and the Vulcan are happier geared higher with the 70+ spurs.
I've ran 75, 72, 69, and 66 on my 17.5 motors and almost never changed pinions. It's either a 32 or 33 when I run 17.5.
