Making Slicks out of Short Course Tires
Hi, I am wondering if anyone knows the how or what the best way is to make slicks out of short course tires. I am going to the Chi-Town race at Leisure Hours and I here they are all running slicks. I would like to know how they make these and/or is the a best way to do so.
Iv made dozens and dozens of sets of slicks this way.... we used to run slicks at my home track when we ran our clay wet. Wet clay + slicks = better grip than carpet. The best way is to chuck a sandpaper wheel/drum into a dremel and dremel off all the pins. piece of cake.
Panther make a slick sc tire http://www.panthertires.com/store/in...&product_id=68
+1 on the sanding them down. I used some Jconcepts goosebumps green compounds. Sanded the tread off and WOW, what a difference. Don't run them down on the street. The asphalt will leave a coating on the rubber and you won't have as much grip as if you sanded them down.
I race there slicks are legal. And IMO use the Jconcepts gold clay barcodes to make ur slicks, their wider than others. I run Ions when it dries out a bit. But a ghost pin works well I hear also. Havent tried that yet.
I haven't had good luck with the Panther Slicks, but I've heard if people lightly sand/scuff them up a bit, they work well.
I personally found this past weekend at the Presidential race at LHR that I liked the JConcepts Double Dee's sanded down slick over the Panther slicks and the Proline barcodes sanded down slick. The Double Dees had a slightly wider profile, maybe it was just in my head but it felt slightly more locked on corner exit.
As for how to do it, I usually chuck up a course sanding bit into my dremmel to knock off the pins and get it close to a slick, then put the fine bit on to smooth it out and make it look nice. A guy sitting behind me suggested I work a bit slower than I was so I not overheat the tires, apparently it can change the chemical compound and the tire won't work as well. I dont know how much truth is to it, but another thing to consider.
Ghost pins worked ok on my buggy in the main, but I ran pressure points all around on my 22SCT in the main and it was junk. I would have ran ghost pins instead if I could do it over.
The chi-town race is NOT a roar race.
You will want to have THREE sets of tires.
Full slicks
Ghost pins
and something with super low trim lines (pressure points)
There are a few methods to get the tread height down.
Run them in the street
Run them over a coarse sand paper
dremel (my method)
If you're running an SC10 on hex and are in desperate need of tires, come see me. I'll have a few extra sets
Full slicks
Ghost pins
dremel (my method)
