TLR TEN-SCTE 2.0 Kit Thread >
Like Tree10Likes
Old 02-27-2013, 12:31 PM
  #931
goehm's Avatar
Trader Rating: 45 (100%+)
Originally Posted by POWESKULL
Why don’t they change them? This is not a hop up or upgrade it’s a part that actually works and doesn’t leak or lockup after rebuild. This to me is the same as the malleable pins that needed to be recalled. They also need to change the soft as butter outdrives.
So the 2.0 isn’t a true TLR but a SCTE that has all the flaws fixed with race equipment thrown in. I am not trying to be offensive but why not fix the flaws in the 1.0 while at the same time make a new car that has all the true racing equipment? I mean why are the flawed diffs and outdrives still being made? They are making a flawed part on purpose now while they make the correct part at the same time?!
I'm not a rocket scientist, and this is pure speculation, and I've only given this about 2 seconds worth of thought -- but I don't think they're continuing the Losi TEN-SCTE 1.0. Current inventory of 1.0's will most likely continue to sell, perhaps at a reduced rate, until they're all gone.
I mean, I'd love to buy a 1969 Camaro hot off the assembly line, but Chevy is only selling 2013 models.
goehm is offline
Old 02-27-2013, 12:35 PM
  #932
Casper's Avatar
Trader Rating: 34 (100%+)
The 1.0 still has it's place in the RTR/ARR market.
Casper is offline
Old 02-27-2013, 12:39 PM
  #933
POWESKULL's Avatar
Trader Rating: 32 (100%+)
That was deep did you stay at a Holiday INN last night?
POWESKULL is offline
  #934
drepus's Avatar
Do the new diffs come in the 1.0s or do they still have the crappy diffs? I want to buy another 1.0 for spares but not if the diffs are still the crappy ones!
You should be able to find some good deals on 1.0's shortly and the new diff cases are quite affordable to buy seperate. Ask your LHS if he would package the new cases with a 1.0 for you!
drepus is offline
Old 02-27-2013, 12:41 PM
  #935
Trader Rating: 25 (100%+)
Im sure once they run out of stock of the old diff case the 1.0 (if they still sell them as ARR) will come with the new diff cases (maybe?). Im sure they would rather only have 1 mold / press running for this...
agarabaghi is offline
Old 02-27-2013, 12:42 PM
  #936
goehm's Avatar
It's been so long - I totally I forgot they came pre-built. LOL
goehm is offline
Old 02-27-2013, 12:43 PM
  #937
POWESKULL's Avatar
Great point and your right they are pretty cheap. I just built three of them and they work great. I was thinking of building complete clips to interchange when I did diff rebuilds and stay on the track while doing it.
Old 02-27-2013, 12:49 PM
  #938
Originally Posted by jayhawknavy02
The old gears are still used with the new HD Housing TLR332001 , correct? I assume all I need to do is remove the 4 tiny shims, other than that, everything from LOSB3569 remains the same as far as gears and assembly.
Thanks!
That is correct sir!
Check it out: http://losiracing.blogspot.com/2013/...uild-tips.html
RC-Rick is offline
Old 02-27-2013, 12:50 PM
  #939
XRated SCT's Avatar
About to go to my LHS and order mine can't wait
XRated SCT is offline
Old 02-27-2013, 12:53 PM
  #940
Grandturk's Avatar
Some disassembly required!
Grandturk is offline
Old 02-27-2013, 12:55 PM
  #941
aaron_buran's Avatar
Default Body mounts
I have a nice new body done up, are the mounts different on the 2.0? Should I save it?
Thx,
-A
aaron_buran is offline
Old 02-27-2013, 01:08 PM
  #942
Grandturk's Avatar
Thx,
-A
Yes the body mounts have a 4mm spacer added to them so they are in different positions. You can run the body mounts without the spacers, but then you will be limiting your shock location tuning options to 1.0 positions.
Old 02-27-2013, 01:34 PM
  #943
Originally Posted by hacker07
They are printing all of the orders now and the website updates only happen overnight.
Hi Ryan, so for those who ordered the parts to convert to a 2.0 from HH, those are shipping too or we talking only kits and/or to partners?
Thanks!
RC-Rick is offline
Old 02-27-2013, 03:03 PM
  #944
Thanks!
I think these may be a bit behind all of the vehicle orders. I will have to check on that.
hacker07 is offline
Old 02-27-2013, 03:40 PM
  #945
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
Things like this being posted when knowledge isnt there is what makes things go downhill very fast in life.
Only one person ran and he is a decent driver and that is John Shultz. He did get second behind a ringer that should have been in the pro class. Class act there.
Only one driver for a huge race like this ? All the big names were there for buggy ......
Hmmmm maybe I should have specified which class I was talking about ? Don't see a Losi on the box for PRO 4x4SCT
BashemSmashem is offline
