TLR TEN-SCTE 2.0 Kit Thread
#3331
#3332
I got everything together on car and the diff and pinion on front have a real bad tight spot, spin by hand you can feel it then goes free again. Almost tight enough to use some real force. With this straightn out not really wanting to tear it back down wanting to run it first time this fri?
#3333
Guys ! There is nothing wrong with the screws , you just need an MIP wrench .......And all this binding in the diff cases ? Nothing wrong there either
#3334
#3335
I also had binding but in my rear diff., yes all my stuff was properly placed in w/ patience, after a lil bit of running the binding was gone, I took apart most of my 2.0 to clean up and maintenance and after taking apart my rear diff. 2 teeth got shredded off the ring gear and they were 1 tooth apart from each other so to me it made sense that maybe something wasn't sitting right and that's what caused the binding then it stopped cause those 2 teeth were gone even though it was properly installed
#3336
Yea it didn't seem like it made a big difference in driving but since I had it apart I just ordered a new 1 so we'll see what happens when I install that 1, but if you end up taking your diff. apart anytime soon let me know if any teeth are missing
#3337
Took all my riffs out for a service, and I had no missing teeth on any of my ring gears, but both front and rear riffs were bone dry. The centre was like 1/4 full. They were build no different than the hundreds of other year diffs I've build, so no problems there. I'm definatly not impressed so far with how fast the diffs leak. Only 1 club race! Anyone else run into this issue?
#3338
#3339
I have built may diffs over my 28yrs. of racing, most diffs leak alittle over time also diff oil heats up an somehow goes away.I do coat both sides the diff gasket with Lucas red/tacky and this helps in that area alot. just my .02.
I also use alittle of this greese on the ring/pinion.
#3341
#3343
I cant believe you broke some teeth off the ring gear, that is amazing. I have seen people skip those for months and never lose a tooth. I would call CS and have them send you one, thats not right at all.
You may not have gotten them tight then. I just took my rear diff apart from the first build of this truck and my diff was still full. But thats my experience. You have to make sure you place plenty of grease in the grease groove of the outdrive.
Seeing that yours haven't leaked I'm thinking maybe I didn't tighten them enough cause I was kind of scared of stripping the screws cause they seemed like they wouldn't go anymore, when I rebuild them I'll tighten them so more
#3344
Yea I thought it was weird, I already ordered a replacement cause the cs has helped me out w/ 2 new diff. casings and some shock caps so I didn't want them to think I'm just trying to get a bunch of free stuff lol.
#3345
