Losi motor running backwards
my buddy (thanks Chad)let me borrow his dex 210 which he just changed from mid motor to rear. he has a tekin rs in it. I cant get it to run forward, only reverse. I have followed tekin trouble shooting advice without sucess. The motor in this rear motor configuration is on the opposie side then normal. Any ideas?
If you are holding the motor in your hand with the pinion end facing you and you apply throttle forward it should be running counterclockwise.
The motor should run in the same direction regardless of the transmission being mid or rear.
Are you also using his radio ? if not and you are using yours it's simply the channel needing reversing in the transmitter.
Ah, on second thought what I posted probably doesn't make sense, oops. Perhaps it is 3 gear but without the motor mounted on the correct side?
