But oil weight is not oil weight. cSt is cSt though.
I've had the most consistant results that are easier to dial in with PTRC fluids. Sometimes I feel like Ae and Losi fluids are bottled wrong. (30 in a 40 bottle etc. etc.)
(CST) |
Im running Losi fluid in my bomber oval car and stock SC10.
The Losi fluid is a little more higher quality than the AE fluid. The losi fluid doesnt leak out as fast as the AE fluid but it still leaks and is the same consistency. I filled my bomber gear diff with 50,00wt losi diff fluid and it hasnt leaked out yet. Any gear diff will leak thou, unless you use Associated green slime. |
I have been back and forth on oils. I prefer the Losi mostly cause it doesn't foam up as bad and the air bubbles rise quicker.
Originally Posted by fullsyzz
(Post 11539255)
Losi oil was known to about 2.5wt. lighter than AE oil in the past. Not the case any more?
Also, if the oil was dark when you changed it that means it was dirty. Happens to all shocks over time. |
Originally Posted by Zerodefect
(Post 11544733)
(CST) |
