MIP CVD ?
Hi, I'm new to the site and this is my first post. I'm running a Stampede 4X4 with MIP CVD's. Well, the other day I was putting the wheel hex's on and I seemed to have stripped out the small socket set screw that holds the hex to the axle (the hex head and not the threads). I would really appreciate it if someone could tell me what the sizing of the set screw is so I can get a replacement. Also, is that a 1.5mm driver to put it on? Thank you in advance.
CPG |
http://miponline.com/store/media/myi...1109-page1.jpg
Follow the part number you end up with: http://www.amainhobbies.com/product_...FY6DQgodZQ0A_g |
Thank you very much for the prompt reply.
I still have a question...
It seems that every set that I run into are 6-32 x 1/8. When I look on the MIP diagram it states 1/16th. This means the 1/8th set screws would be twice as long, right? Am I missing something here, please explain. I'm just thinking that 1/8th's would probably stick out and prevent the wheel from going onto the hex? The info seems a bit conflicted to me or maybe I'm just not understanding. Once again, I really do appreciate the help.
CP |
1/18 or 1/16
I'm sorry if I double posted, new to the site. I guess what I'm trying to find out is if the hex's are held onto the shaft by 1/8 or 1/16 set screws. The diagram that was posted shows 1/16th, but I can't find them anywhere?
