Tekno SCT410 Thread
#7006
kevin, what pistons are those?
#7007
any set up suggestions for tekin rx8 4600 with 15 pinion
the truck feels sluggish with this set up so had to go to throttle profile 4
might have to try 5 just to get that boost at the start of the throttle curve
#7009
Thanks Tim!
Guys keep in mind the shock locations and springs are what I wanted to highlight. The rest of the setup is a work in progress, especially the diff fluids. I'm probably going to go 7/5/3 on a loose track next weekend. Would be great if you guys can give me some feedback and we can keep improving it.
#7010
#7011
#7014
I am very interested! Same issue after 2 wks and 2 broken axles I havent had enough time w it to correct the loodse rear
#7015
I'm running a 13 pinion, 65 current limit, and the throttle profile *below* linear (TP 2?) with the same motor/ESC. The truck has gobs of torque and hauls plenty of ass. Is there a reason you need the 15t? I would start by just dropping it to 12-13 unless you really need top end.
#7016
temps are fine 130 max. I just need a little bit of ump to swing this truck faster
might have to try a high torque 550 novak to see if more torque would be perfect for my driving style
thanks
#7020
^^ Ya, what he said
I'll do ya one better, here's the whole setup. It is quite different than the direction most others are going, but its working really well for me so far. I spent last weekend working with my EB48 so I didn't get to run it again. I'm headed south to ED's RC in Parkersburg to run the SCT410 only, I'll post back on how it shakes out.
WOAH!!! there will be no stroke information exchanged in here!!
