Tekno SCT410 Thread
#6016
I got two for it the SCT body is the new J Concepts #0058 Illuzion Manta and the Parma #1238 55 ChevyAttachment 1037760
Attachment 1037766
Attachment 1037768
Attachment 1037769
Attachment 1037770
Attachment 1037766
Attachment 1037768
Attachment 1037769
Attachment 1037770
Im totally getting this body now that I saw it next!!
#6018
My local indoor track has two of quick doubles that are speed bump size that are causing my truck to stay nose down in the when i jump them and it is costing me time when i land cuz the truck is slightly out of control when it lands. The losi trucks handle it well whether they downside the jump or land flat. These are low speed jumps that are easy to clear but my truck doesnt handle them well at all and this is where i lose time. i have been practicing tons lately and adjusting the setup to get it right but no luck. Even throttle when in the air doesnt help at all. I used multiple throttle techniques to get it right but no luck.
Current setup
diffs 5/7/3
Front
Serpent 10 hole pistons 5 holes drilled to 55/ 5 holes drilled to 56
40 weight losi oil
springs Serpent pink(pretty soft)
frt shocks 3/outer upper on the a arm
links 2/b
stock bump steer/ ackerman
camber -2
rde hgt 25mm
Stock front arm sweep
Rear
Serpent 10 hole 1.1 pistons
25 weight losi
spring Serpent purple (medium soft)
Shock location 3 on tower and upper outer on a arm
links 2/c
camber -2
ride height 26mm
Stock toein antisquat
Rear hubs have 1mm spacer in front and 4mm in back
Center and rear chassis brace removed.
What do i need to do to keep thhe front end up?
Love the truck as i have already won races with it that i never did with my old durango.
Thanks for the help
Current setup
diffs 5/7/3
Front
40 weight losi oil
links 2/b
camber -2
rde hgt 25mm
Rear
25 weight losi
links 2/c
camber -2
ride height 26mm
Thanks for the help
#6028
As I posted earlier mine is doing the same nose down jumping. Tomorrow I'm going to build a 2FT high jump in the yard and see if I can get the same nose down result. If so, then I can start changing things one at a time to see what happens. It's hard to do this kind of testing at the track because it just takes too long and there are too many other distractions going on.
