Tekno SCT410 Thread
#2686
You don't need to be a member to get a discount on tower. The cheapest I could do, with tower, was 359$ shipped. With a code.
Amain, has the truck in stock, $25 off code, plus shipping, put me at $389.
$30 more than tower, but I'll have the truck in week.
Who knows how long to get it off back-order from tower. Everybody on the Tower list just got moved up 1 spot......
#2687
#2688
Does everyone use the supplied grease on the diff o-rings or is there something even better?
#2689
#2690
whats a good combo to uesd on this truck on a 1/8 scale track with two long strights
#2691
I need a bit of help with my ride height. I just finished building my kit this evening and I followed the kit set-up exactly. I have the rear shock collars all the way at the top of the shock body and I'm still at 26mm of ride height. The kit set-up calls for 25mm of ride height. What am I missing?
#2692
#2693
#2694
#2695
#2696
Tech Legend
Cain, that's a bad idea... I stripped that wrench from my 4x4 in about 5 seconds. I use the stock losi one I and it works great. You need a wrench that will fit like a normal open end wrench or it will strip.
Gonna run mine again this Saturday and do a little tuning. Best driving 4x4 I've owned to date.
Had first issue, needed to cut a screw as what was supplied was too long. Not a big deal but considering how well everything has gone together lol.
I also noticed the manual doesn't say anything about putting in the side screws for the servo mounting. It mentions the standard ones that go through the holes on the case, just not the sides. again, not that big of a deal.
#2697
can anyone tell me what the team associated shock oil equivalent to what is in the kit, i know it has been said befor but i cant find it. that is what my LHS keeps in stock
#2698
http://www.falconsekido.com/products...c-for-1-10-car
XERUN Sensored Brushless 3656 4700 KV
http://www.falconsekido.com/products/xrm3656sd
I run this setup
#2699
Just finished my build. Man what a truck. I really like my other trucks, but this one is impressive at least on par with my X-Ray ebuggy. Really looking forward to the first race of the season on Sat (if the weather holds)
Trying stock set up, but I have been reading that the back end can be slightly loose. One way to help is to remove the rear and center braces. Did I read this correctly?
