Tekno SCT410 Thread
#2356
tekno sct 410
john bernard put one of these together last thurs and fri night box set up, ran the truck race at go hard sat TQ ed and won first race with almost no practise,mine will be here weds cant wait
#2357
Cain,
Yes there are a few benefits to the aluminum hexes. The first being you are less likely to strip out the wheel, as the aluminum hex does not flex like a plastic hex will(if a wheel nut were to become loose). Second is that with a aluminum hex you may torque the wheel down more and not have binding because of the flex in the plastic piece. Lastly the aluminum hexes are clamping hexes so when you pull your wheels off to clean and work on your ride they will not come off and eliminate the problem of losing a hex pin.
-Thomas
-Thomas
#2358
There are going to be many set-ups for the truck. Just going to depend on driving styles and what your looking to get out of it.
#2360
Kit setup is the correct starting point(center and rear braces are optional), but the braces for us are used for tuning on a high bite track without the center and rear braces we get better traction as it allows flex in the chassis. On our track we prefer not to run the rear and center braces. I believe as well it says in the manual that the braces are optional in the center and rear. Everyone drives different and every track is different, you just have to try it out and make changes from there.
-Thomas
#2363
Have a question on the area size of the esc mounting area. What are the dimensionsog the mounting area? And is it the same on the EB48 (got my eye on that buggy too)? I currently run a Novak Activ8 esc that has a pretty large foot print at 40 x 54 x 31 mm (1.57” x 2.6” x 1.22”). Thanks.
#2365
Teeforb,
Any Mod 1 pinion will work, it depends on the Kv of the motor as well. For 4600kv we recommend starting at a 15-16 depending on track size.
We offer aluminum hexes for the truck TRK 1654X.
http://www.teknorc.com/shop/tkr1654x...d-ae-sc10-4x4/
I have beat the truck really good at SDRC this past week and have yet to have a problem, I am however running the front aluminum Hinge pin holder that was supplied with the kit.
-Thomas
-Thomas
#2367
So with a 4600 on a medium sized high bite track a 15t should be a good starting point?
Going to finally get my butt in gear and start building these things!
#2369
Hinge Pins
http://www.teknorc.com/shop/tkr5017-...etal-anodized/
I noticed in the option parts, that the hinge pin holders only come in pairs.
Since we already have 1 on the truck (thanks for adding that), is there a plan to make the other half available separately?
#2370
Yep, 15t should be good to start with on either a Pro4 4600 or an SC411 5200. I've been running the same gearing on both for a while now (was 13t in my SCTE). I seem to pull a bit more power now than with the 13t on the SCTE and gain a little more speed, but I'd say it is the best starting point for anything but a wide open outdoor or really tight indoor track.
