Tekno SCT410 Thread
#2296
I ran mine bone stock today except the rear hubs with outer for camber. Trucks better than my lightened scte for sure. Its more nimble but more stable as well. Think its because of the shocks. Overall very happy with it.
I had horrible luck with the wheels though. They stripped the plastics kept coming loose (used premount gridirons SS). Is the losi aluminum hexes a direct bolt on? Also the servo horn is junk stripped in one whack. Put the tlr in and its golden. Ran a 16 pinion and temps are fine but will need a fan in summer. Ran a 18T as well but ESC was going nuts HW scte pro with 4000 kv hobbywing. I might run the tekin 3300 with 3s and rx8 for more speed maybe. Overall I love this truck!! Thanks tekno!!
I'm currently running the Tekin 3300 Pro 4 with an EcoPower 3s 3400 pack, it's working really well. Using a 14 pinion everything runs cool.
The camber links are 5mm and the steering links are 4mm dia. Can't recall the lengths, maybe Danny will post them up.
#2297
Do you mean the wheel nut is coming loose? It's serrated and you can crank on it so that really shouldn't loosen. A bolt-on aluminum option is TKR1654X. They are a +1mm option so your truck will be a little wider but still legal. Not sure about the Losi hexes, I'll try them tonight and see if they fit.
#2300
Any Word on when the next shipment is going out to the Hobby Shops? Mine has been on Order with tower for 2 weeks and still haven't heard anything, I'm dying to get my hands on this piece of Mechanical greatness!!!
#2301
Here is a shot with center diff removed. The dogbone would stand up in the drivecup because of the bind.
#2306
#2307
You are making it way too difficult LOL!!! AE is thicker (Scale wise) than Losi according to everything I have read and that chart I posted as a quick reference. Look at the chart.....a Losi's equivalent of 25wt AE is 27.5. It takes a thicker Losi oil (27.5) to equal the same weight AE (25) I can't help you on the Tekno stuff.
#2309
disregard
#2310
That's correct, Sean... it is the FTW Diambondback, body. FTW did an awesome job with the lines on it and look even better in person. Pyro (https://www.facebook.com/scott.beran) is one of the best painters in the world (does lots of the Pros' lids)... lucky to have him living right here in the 'Natti. I can at least look fast.
Sean, haven't had time to catch up on this thread, did you get your issues resolved? If not, meet me up at the Factory on Thursday night and I am sure we can figure it out.
