Tekno SCT410 Thread
Kidding of course, no clue your situation. However in my situation, it's never the network
Tech Legend
lol, for me at least, I have the "benefit" of trying to fix stuff the vendor gave us in addition to network stuff.
What track conditions do you run on?
Fioroni Ergal Dual Action 6 Hole Shock Piston Set 16mm - FIO-OT-UR916
Is this the correct shock pistons that Sramos is using, can someone chime in here plz, want to order but make sure I get the right ones, TYVM
Yep, 16mm.
Ok i been running this truck about 3 times on some outdoor tracks in the NE . Well i cant seem to be constant with it in with the stock chassis/towers on looser tracks.
Basecially if i try to push the truck with half steering or more on power the Rear end likes to get loose / not super loose if i try to push the truck . I have the center and Rear braces off.
The only thing i can think is that i need to go up on the rear diff like 4k with a 5,7,4 diff setup ?
What does this truck like to be driven like in stock form hard or smooth ?
Truck jumps fine for the most part.
But when i had the MIP SCTE i seemed to be faster with it but than again it could be because i ran it for longer . I like the Tekno truck but i guess i need to just tune on it even more .
Tech Legend
personally, for more rear grip I went with:
- Lower rear link on tower
- Shorter link
- lighter diff fluid in rear
Those are some of thethings I personally tried. you may find some combinations of those work better for your driving style.
- Shorter link
Ok thanks . Il try that out on the rear tower going down from the middle hole . The shorter link are you talking about on the rear hubs the hole on the far outside ?
One thing i noticed when i ran soft Endoros when it went on power on some turns not super fast the truck would roll over could be the JC high flow body top heavy on the roof ?
Tech Legend
for the links I went in on the hubs. Mainly got this from reading up on the Mark pavadis guide, worth a look, that and the hudy setup book work well.
Mom came in second, that's so cool! I'm stoked when mine goes once a year for practice with her mega dollar 1/8 buggy. Yours finish put a big smile on my face, keep up the good work. Keep and eye on mom she might be in 1st next time....LOL
Your light front diff may be generating too much off power steering, resulting in a loose feeling.
work all day "figuring" out the problem! Just before it's time to go home to practice, plug 'em in, everything is up and running and you walk out a hero!
Have you tried 10/7/5 in your diffs yet? I would give it a try. I run this setup with a stock chassis and it works great. Running 8x1.3 pistons with yellow rear springs, and on loose tracks, it's really consistent.
I havent tried out that diff setup but i was going to try out 4k in the rear diff from 3k . Yea i went with 5k in the Front diff for off power steering on the indoor tracks but outdoor it does seem grabby on the steering. And im thinking causeing wheel spin making it loose.
So im going to go up to 7k in the Front diff and leave at 7,7,4 or 7,7,3 .
I did think at first that using the 7k in the center diff with the 3k in the Rear diff was sending to much power to the rear making it loose.
Ive been running the Green springs all around on the Front 32w/1.2 , Rear 30w/1.3 8 hole pistons. I was really thinking about going up to 35w/1.3 up Front to calm down the steering anyways. I have my eye on the Yellow Rear springs.
