Tekno SCT410 Thread
fioroni pistons
i tried this weekend the fioroni pistons and i wasn`t too excited about it!
i still pulled TQ an Win but i was fighting with the car.
usually so easy to drive but this time the car jumped funny and was loose in turn.
before i was using 8x1.3 pistons with 35Fand 30R yellow springs all around
after i switched to fioroni pistons i started with 32.5F 27.5 R with yellow springs
the car was slapy after i change it to 35F 30R was better but way of how was use to be.
i guess im going back to 8x1.3 pistons
Need input on servos Savox SC-1258TG, the Hitec HS-7955TG or something else?
I love this truck everywhere on the the track except over the jumps this Damn nose diving thing is getting on my last nerve lol
What diff fluids is everyone running outside, got a halfway decent setup but just want to get some other ideas for this year. Track can vary from dry and dusty to wet and crazy traction.
Great choice
Tune it out. Harder rear spring or thicker rear shock oil. Try standing the rear shock up a bit.
I start with base setup of 7F 10C 5R
Why does everyone complain about the truck nose diving?
You know what i been figureing out with this truck with how to jump with it without nosediving it to much. One thing is try to hit the jumps at a slower speed when you appouch the jumps pretty much just go with the speed you need to clear them and the truck will jump pretty good. If you hit the jumps at more speed than needed oh it will nosedive !
I think thats dued to the battery being to forward or not enough droop in the Front or the Rear . Than you have the shock pistons you use or springs than factor in with the nosediving.
Im not so sure about using thicker shock oil in the Rear shocks if you racing on low traction at least it will take traction away. But it will make the truck jump better usually.
All i know is though that the Green springs all around are better for sure than the Black Front, Pink Rear springs. The truck does not feel lazy like before.
It's not the springs we have been using anything from grey on in the rear if traction needs it.
