Tekno SCT410 Thread
Maybe in a couple turns. Our tracks are pretty high bite down here so I usually have it set to turn pretty aggressively. That run was after we finished running the 4wd A-Main and the 1/8 A-Main. There was some dust out there and I didn't care enough to blow it off again.
I wish I had video from the indoor track. I ran slicks and that thing drove like my touring car.
Right now I run emulsion with X-ray 6x1.3 pistons in all 4, front losi 37.5 rear losi 25 oil, pink tekno spring in front and orange tekno spring in rear. The feeling you get from the emulsion style I think is from the plastic cap. It does not seal very tight like the scte caps do. If there was an aluminum cap for emulsion I think the shock would feel better. I think I will go back to bladder with the same setup till they make a new shock cap.
Did you ever try it with a cut out bladder instead of the o-ring? I remember people mentioning it way back but I never tried.
I have not used a cut bladder. I think it is mostly the bleeder screw with the oring and some with the plastic cap having some flex under compression.
I thought about using a button head screw instead of the flat head but I can see what you mean. The cap is pretty large.
ok guys, my buddy wants to pull the trigger on one. i recommended a 4 pole motor but he wants a 2 pole because he has a speedo for it. i've told him most of us if not all are running 4poles due to it being a lil heavier then most sct's, and the 2 pole prolly wouldn't cut it. but in the end i don't know much about 2 poles because i've never ran them, so he wanted me to get on here and ask you guys what 2pole you'd recommend. (i still think he needs a 4 pole but he can be stubborn sometimes lol)....lemme know so i can relay the info
I am using the flat head with orings in the emulsion hole and the thin oring to seal the cap. I haven't had any seeping from the screws or the base of the cap. But I do like the set screw idea and will throw some in before next weekend (running emulsion build for a few days of driving now).
Found it! This is taken from RCShortCourse, written by Shark413.
A minor update. I built my shocks as bladder type. The shock can be setup as emulsion or bladder (with/or without vent and bleeder holes). The caps have spots marked on them that you need to drill out depending on what you plan on running. I went with bladder with a bleed hole, so I drilled out the bleed hole. There is a hole for the emulsion setup but it is not drilled all the way thru, and since I went bladder it sat empty. I didn't like how the hole was exposed and would get full of dirt, so I tried putting the emulsion screws in just to act as a cap. But I didn't like the look so I got some 4mm set screws and installed to act as a cap for the hole.
Here is the empty hole for the emulsion bleed.
Here is the stock emulsion bleed screw and seal, kind of ugly. You can also see the bleed hole I drilled in the side of the cap. The holes are all pre-marked to help you get them right.
I added a 4mm set screws to seal the empty hole. I think I saved some weight too.
so I swapped the pro4 4600 for the pro4hd 4300 and I cant say that I noticed a huge difference w 18t pinion in pro4 vs 18t in hd. I was looking for more pop to clear 2 jumps that I land just short on even when approached perfectly. Should I have done something differently?
Just gotta build my shocks and drop in my electronics. I got the aluminum balls that go in the bottom of the shock, how do I pop these in that plastic piece without wrecking them its a tight fit? Thanks guys.
So I should go up to 19t maybe even 20t with the 4300HD?
