BEST RUNNING TEMPS FOR TRAXXAS & CASTLE SYSTEMS
I have already done my own research on this but i wanted to hear more opinions to complete my list, specifically from this forum and so that i can have this information under my own post for future reference.
Below i have listed all the electronic systems that i would like your opinion for as well as my findings for some of them. You are welcome to comment on any of the systems below.
These are my Findings:
Castle Creations Systems: (ON 4S)
MAMBA MONSTER ESC (E-REVO BL):
Didnt manage to find any information
MAMBA MONSTER Neu-Castle 2200kV motor (E-REVO BL):
BEST = 150F
GOOD = 160F
LIMIT (do not exceed) = 170F
MAMBA MAX Pro ESC (FLUX 2350):
BEST = 130F
GOOD = 140F
LIMIT (do not exceed) = 150F
FLUX 2350 motor:
TRAXXAS Systems: (ON 4S)
Velenion VXL ESC (1/16 E-revo):
BEST = 140F
GOOD = 150F
LIMIT (do not exceed) = 160F
Velenion 380 BL motor (1/16 E-revo):
BEST = 140F
GOOD = 150F
BEST = 150F
GOOD = 160F
BEST = 130F
GOOD = 140F
FLUX 2350 motor:
BEST = 140F
GOOD = 150F
BEST = 140F
GOOD = 150F
Im fairly certain that the max temp wouldnt change depending on whether your running 4s or 6s. For most motors 140 to 160 is the sweet spot and you generally dont want to go over 180. Just keep in mind that the internal temp of the motor may be 15 to 20 degrees over the external temp. So when your temp gun reads 180, the actually rotor may be at 200!
So in a perfect setup is the motor supposed to be running hotter than the esc?
anyone?
Pretty much any motor should be safe up to 180*F. You start risking rotor damage up around 200*F+ for extended periods of time.
Basically, keep it at 180*F or under no matter what, meaning gear and set it up properly for how long you drive. If you're just doing 6 minute heats and mains and it's coming off only 130-160, that's fine. If you go and run for a full pack and it comes off 200*, you need to tone it back a bit to drive it for that long and keep it below 180*. In general, just keep the motor at or below 180*F and it'll last you a long time, no matter what brand.
Yes I'm sure. Some manufactures may use different magnet materials and don't recommend over 160*F but really that is just to cover the bases. It all depends on the motor and application, but in general all brushless are safe up to 180*F and start to demagnetize the rotor at higher prolonged temps.
Is it also true that when you record the temperature of the motor you should add up another 20F because the motor is hotter on the inside?
