Team Associated SC10B Race Buggy
#751
I'm relatively new to Team Associated but I can already tell from the designs of each kit that definitely aimed at the intermediate r/c market and even to the professional racers.
I've only owned a heavily modded FT Tc3 back when I raced 1/10 TC and even with all the hard crashes, traction rolls, cartwheels, the only things that break are easily replaceable with stock pieces again saving weight and cost.
Then I built up a FT RC8be thinking I would have time to race on and off road. Well didn't really get to put the buggy through its paces but the build was one of my favorites for sure. Now I just got the Sc8e.2 and transferred all my RC8be electronics over and couldn't be happier.
Next Team Associated I just had to get was the sc10b. It just drives and jumps smoother and more predictable than my Losi XXX-SCB. So far my favorite Associated rig is the sc10b...Savox 1251MG @ 7.4v lol and the Castle Sv2/3800kv 4pole setup minor gear up...Smooth as butter and just insane nimble and fast!
#752
R/C Tech Elite Member
I had all Team Associated 2wd offroad cars and the SC10B is by far my favourite. It handles great, looks awesome and is very fun to drive.
#753
How does this compare to the short course trucks? I never liked the parachute effect of the trucks and I love the look for this.
#754
It will be right up your alley then! It has all of the good stuff about short course, mixed with all of the good stuff from 2wd buggy. These things really are the best of everything IMO. If they were 4wd, it would be the only car I'd own lol. These are by FAR my favorite 2wd, and I've had all of the AE 2wd cars as well.
#755
#756
I tried racing with an Axial EXo Buggy. But there just wasnt enough parts support and fine tuning I could with it. Plus 4Wd is a dead catergory in the Phoenix area. The short course trucks bashed it on the track. I gave it up and bought a SC10B after seeing what was at the track.
#757
Here is a shot of my SC10B.2
Super badass paint job by 40bux.com aka psychedelicRC.com
started as SC10.2 and converted to short course buggy.
Tekin RS, Tekin 10.5
Savox 1258tg
LunarRC ackerman bar
RPM ballcups
integy front/rear lights
axial light cups
proline holeshots m4
and thats really about it!! Thing is freakin dialed too. In the last 3 races I took 1st place in 2 races, and 2nd in the last race. I have a blast with this thing!!
Savox 1258tg
RPM ballcups
axial light cups
#758
#759
#760
What is the strongest rear cvd set for the sc10b? I'm converting mine to a beach buggy so time to beef up all I can the stock camber links are already starting to bend a bit on my test run 3s sv2/3800kv with CC BEC at 7.4v powering a Savox SC-1251MG low pro high speed servo, but im experiencing very bad stuttering when I just start to input throttle. I think it's a tranny issue...maybe the idler gear chipped a few teeth? It's unfortunate they don't make hardened steel tranny gear replacements for those that bash only.
I also noticed that my sv2 blinks orange and red rapidly while its stuttering with rear wheels off the ground. Tried recalibrating but didn't work same problem.
#761
http://miponline.com/MIP/Home.html
#762
#763
#764
Wow so I actually bent the front camber link driver side right where the threads meet the ball cup lol! All I did was jump a little 2' sand ramp on a volleyball court didn't even flip it once.
So upgrading to lunsfords now and run the cups that come with the kit. Or should I go for the RPMs?
Running gear is top notch now....next up will have to be either the MIP cvd's or the FT CVAs.
Which one is tougher I need it to handle 3s and paddles on sand.
Since I do a ton of beach running with paddles and beadlocks. This buggy doesn't see tracks only sand and street. Of course I adjust the stock slipper accordingly.
So stock shocks are fine, just replacing things as they break.
#765
Hey guys so I have this sc10b,mainly using it for bashing in the sand, I did a few mods listed below.Tried the stock RTR shocks,proline powerstrokes and lastly the scte shocks. All setups seem to work pretty similar in that the buggy seems to nosedive most of the time on the practice track. I wanted to swap the gear diff out for a ball diff.... I had a spare tranny for my b4.2 all ready to go and figured I would try it with a b4 wing mount and no rear cage/bodywork. After installing it I got carried away with the body scissors and trimmed out the body to sit level with the side top bar of the cage. basically lowered the side panels to look less bathtub like. Let me know what you think so far.
Scte RTR shocks with a/e 1.6 pistons
Turnbuckles and rpm cups
Castle 3800/sct combo
Xp1015 servo
Losi xxx sc wide hex's Rear for scte wheel offset
Swapped the front stub axles for RTR rear outer stubs for wider offset
Cva's and .5*alum hubs with B hub installed
Xp1015 servo
