The AE FActory Team B44.2 Thread
#1891
When I 1st got the kit I tried the Ballast. Ran it one night and a practice night. Since then I have been through about 20 oil and spring combos.
Right now I have in the front AE 1.5 pistons Losi 35 weight and AE Red 3.90 springs.
Rear I have AE 1.6 pistons Losi 27.5 weight AE Green 2.00 springs.
No Ballast.
The set up is pretty good as far as roll. Weight transfer is more Biased to the front. Its a plush feel. I will see if I can find a way to show how it works. It is pretty much what AE 32.5 front and AE 25 rear would feel like if you tried the pistons.
BTW the table test will give you an idea how soft the kit is on the table
No Ballast.
#1892
King Richard...
http://www.youtube.com/watch?v=-hU6B9Z62hw
Give this a try, but first do the drop test and table test with your current shocks. Then top and bleed your shocks this way and see if you can tell the difference?
I feel better pack and and better rebound without changing the springs.
Common way to bleed will have less pack and this method will have more pack.
I have found that 90% of folks really don't know there shocks or the proper way to assemble them. Club racers just don't make the time to study and test test test. This vid may help out and will for sure get the brain clicking.
I should do one that is more detailed. This was to help some one get rid of that 50/50 in out rebound.
UN4RACING...
http://www.youtube.com/watch?v=GitM0-hWFgc
#1894
Manual recommendation. 1 front and rear. Now if you run the rear/front shocks in the inner upper option you will need at least have 2 in the rear and front. The droop will be so low the CVD's will jump out on ya. 3 to be safe. But then I had to unscrew the eyelet to get my droop set where the CVD was back to the stock droop.
#1896
Also, is anyone else switching their stock blue aluminum upper shock mounts out for the plastic ones? I'm doing it because I'm not a huge fan of metal on metal and I can just see the two wearing each other out pretty quickly.
#1897
Yeah, I got lucky with the V2's a built them my first time via X-factory's instructions (which are just like the video except they fill the cap with oil too). I haven't been building them with the collar on though, that's something I'm going to have to start doing. Thanks for the Videos!
#1898
Any time, Just ask if I can help I will. This also helps me to stay sharp and or rethink things. Its always a learning experience. There is actually more to this flat landing pack stuff that's not seen or obvious. I will get a vid up so you can see it...LOL We will all know this kit end to end before were done....
#1899
UN4RACING you truly are an asset to this forum. Thanks for all your time and research put into this car. We All appreciate it.
Coolza
Coolza
#1902
Yeah, I got lucky with the V2's, I built them my first time via X-factory's instructions (which are just like the video except they fill the cap with oil too). I haven't been building them with the collar on though, that's something I'm going to have to start doing. Thanks for the Videos!
With shocks.... The cap will blow off or the seals will give up and piss all over your a-arms.....
My goal is to get the maximum amount of oil/pack for the stroke of the shock. I know we all tried to conquer the chassis slap with the V2's
Here's just how far I have tried to push my shocks. And you will see just how much further we can push our shocks to perform. A lot of the stroke is not used on a shock that we don't notice. You may find yourself really looking at your kit closer after this vid...
Here's another vid to see a part of the stroke that's not used on a flat landing. It is however used on an off camber landing. With a plastic cap V2 I tried to get this last bit of stroke filled with oil or hydra lock it at this point as if I had put an exterior limit on the shaft. Its easy to do. But the ill effect is if you pushed it the cap would blow off of the V2. It worked great until the one to many off camber landings would blow the cap off. If you can fill this last bit of stroke with oil and never let the piston get in this area the pack is greater. The V2 plastic cap on a off camber hard landing just could not handle it. Now I have yet to try it with the BB cause I know it will take a lot of testing. But now you see an area that is best used with bladders thus getting more performance out of our shocks and the bleeding of the shock becomes obsolete.
http://www.youtube.com/watch?v=MGwW7nqzIzc
