BL Motor question on Kv/Turn replacement?
I'll be replacing my stock reedy motors that came with my rtr's soon. The rtr's are 2wd SC10 rs's and t4.1's. The stock reedy is fast enough right now, we do backyard family racing.
The reedy is a 3300Kv, I have no idea what turn it is. Can someone recommend a motor equivalent for me and would this be a stock equivalent? Also, is the reedy 3300Kv a stock motor? I'll be going with a different brand of motor, as I want to get away from reedy...budget is $50-$100 max. Thanks for any suggestions.
The Reedy 3300kv is roughly equivelant to a 13.5T motor. That said, I raced competitively with the Reedy 3300kv in my old SC10 for a while before upgrading. A stock motor is a 17.5T sensored motor. The Reedy has a little bit more power than that, but stock racing is a great place to build your skills and really learn how to setup your vehicles.
In order to upgrade your motor to a true race motor (sensored) you will need to upgrade your ESC. I would recommend upgrading the ESC first and then getting a motor as it will open up more options for you. You can't go wrong with picking up a second hand Tekin RS ESC as they can be found for relatively cheap and will run sensored and sensorless motors. Another viable ESC option is the Castle Mamba Max Pro, but I prefer the Tekin HotWire tuning software and the lower profile of the ESC.
So, stock is 17.5T, the reedy 3300Kv is like a 13.5T, and if I want to go a little faster, a 10.5T would do it...do I have this correct?
More or less. Personally I run an 8.5T in my 2wd short course (when I'm not running stock class) but a 10.5T should be enough power for most people. Do keep in mind the ESC, however, as you don't want to get a motor and then not be able to run it because your ESC doesn't support it.
I will thanks, I don't think I can drop the cash on a Tekin right now, would have to get a more budget esc like a HW or Brushless hobbies.
BTW, what is "relatively cheap" for the tekins you mentioned above?
BTW, I wish I was lucky enough to have a home track!
