Drill and tap pinion gear
Okay so as the title says I'm trying to drill and tap my pinion gear to mount it on my motor so as to not have the gear come off the shaft again so how can I easily drill and tap it because my typical drill bit in my drill press keep snapping maybe a carbide bit but what about my tapping part
Did the threads strip out?
Seems like a lot of work for a $4 part
I would prefer to not use red Loctite on my pinion set screw and the set screw it comes with only has three or three and a half threads grabbing and it has not worked for me with one set screw the last pinion was not hardened
I have always used the blue, never had any issues myself...
Or, skip all the hassle, clean your threads and use a dab of loctite on the setscrew. Thousands of racers do this without issue, you should be able to do the same.
the only time i've had one come loose was because in a gear changing hurry i mounted it on the round instead of the flat spot..get some blue loc-tite gel..it's awesome...it comes in a twist up tube like chapstick
http://www.autozone.com/autozone/acc..._&target=shelf
this looks different than what I bought but the same idea, it's not in a toothpaste tube it's more like chapstick
This pinion on this truck is the only one I have ever had issues with none of my other trucks have pinion issues and I don't know why this one does Loctite has let me down and that's what I have resorted to this crude method of drilling another hole
If this is the only pinion you've ever had a problem with, throw it away and get a Robinson or other name brand gear and be done with it!!!
I've never known anyone in 25+ years of rc racing to have ever needed to do what you seem to want to do to get a pinion gear to stay on the motor shaft.
