RC lubricant?
RC lubricant?
I'm wondering what type of lubricant to use on my rc's. I'm very meticulous about cleaning them after each use. I try to dry them as best as possible using a little pancake air compressor and finish by spraying the metal/moving parts with wd40. I know that's really not adequate as a lubricant, I'm even hearing a little squeaking from time to time. Is there any specific type of lubricant you guys use on your rc's?
I use dry wax like this stuff , just a different brand .
http://www.amainhobbies.com/product_...-Lubricant-4oz
CowRC makes some good degreaser and lubricant. My buddy uses Kal-Gard as well..
I use the reedy motor spray for the initial cleaning of the parts that have grime and grease then spray alittle 30-30 ( a dry lube) from kal-guard to make all the parts free and smooth. On parts like the chassis and arms and what not a little wd40 and rag will do the trick
i use any DRY teflon lubricant...comes in a bottle as a liquid but dries like a dry wax lube...odonnell makes some that seems like a rebranded bottle of "dupont teflon multi-use dry, wax lubricant" stays clean - no oily film...i think i paid $5 at ace for a few years supply lol....to clean the rc i use a toothbrush and air after each use for big crap and i break it completely down every so often and clean every part with soap and water just before new seals/grease/oil/fluids
Here it is http://www.kalgard.com/products/prod...d=762780_OOOO6
