Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Old 01-08-2017, 12:45 PM
  #14086
It was the bottom on the same side, temp was very comfortable 68 deg. Just odd that it happened on the same side 3 times
ruttrowreroy is offline
Old 01-08-2017, 01:28 PM
  #14087
What conditions would you put the shocks on front of the rear arms?
danwilson is offline
Old 01-08-2017, 03:54 PM
  #14088
High grip--- turf.
Old 01-08-2017, 10:12 PM
  #14089
Danwilson, my local track it pretty high grip dirt. Laydowns and shock on the front of arms are on all cars that have the capability. I built my 6.6 from the get go with the shocks on the front of the arms so I don't know what it feels like on the back side of the arms but we are doing this setup to help carry more corner speed.
mbrown6 is offline
Old 01-08-2017, 10:20 PM
  #14090
Originally Posted by ruttrowreroy
I have a RB6 stock shocks and 3 times in races today, I cracked my shock end in half. Could someone please tell me why this is happening. I had minimal camber and haven't had this issue in the past. Any suggestions would be deeply appreciated.
I have yet to have this issue. It sounds to me like your talking about the plastic eyelet piece at the end of the shaft. I can't imagine this happening on the front arm. I could see it happening on the rear arm however if you over tighten the screw that mounts the shock to the arm. I did notice once when I snugged mine down that the screw managed to get tight enough to suck my plastic washer into the aluminum eyelet ball.
mbrown6 is offline
Old 01-09-2017, 04:47 AM
  #14091
eper's Avatar
Trader Rating: 14 (100%+)
Can u post a pic
eper is offline
Old 01-09-2017, 04:53 AM
  #14092
eper's Avatar
Is it possible u are turning the eyelet onto the shock shaft and tightening it to the point that the shock shaft is tearing the eyelet. The eyelets don't meet to be tightened in the shaft. They can actually be adjusted to change droop
eper is offline
Old 01-09-2017, 09:02 AM
  #14093
Trader Rating: 38 (92%+)
How many on this thread run 4 gear laydown ??
Rcforlife13 is offline
Old 01-09-2017, 10:55 AM
  #14094
Thanks for responding, I will keep an eye while tightening!
Old 01-09-2017, 10:58 AM
  #14095
Originally Posted by eper
Can u post a pic
I will try, but yes it is the eyelet that attaches to the bottom of the shock. It's breaking right above the eye.
Old 01-09-2017, 11:04 AM
  #14096
Thx for the reply, I think I am tightening too tight and when I put it on the shaft, causing issues..I appreciate your help! I will make some adjustments and see.
Old 01-09-2017, 12:49 PM
  #14097
Is your track glued together dirt that you run treaded tires on?
The track I'm thinking about trying rear shocks on front of arms is wet clay that we run slicks on I wouldn't call it high grip maybe medium the majority of the time.
Old 01-09-2017, 02:40 PM
  #14098
oPAULo's Avatar
We run 4 gear for mod and 3 gear for stock. That seems to be the norm as far as what I've seen. I've seen a couple people try 3 gear laydown in mod and say they didn't like it. The torque of the motor twists the car to the front in 3 gear and un-weights the rear. It's not as pronounced with a stock motor and less drag is beneficial with a stock motor.
oPAULo is offline
Old 01-10-2017, 03:03 AM
  #14099
eper's Avatar
Usually we measure form the top edge of the eyelet to the bottom of the shock body to set droop. I believe when I ran that car I ran about 21mm of droop. Check a set up sheet to be sure. U can find setups on petit rc.com
eper is offline
Old 01-10-2017, 10:54 AM
  #14100
Default Rb6.6 alum idler gear
Anyone's input on adding these for a laydown 4 gear tranny
