Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Old 10-19-2016, 07:03 AM
  #13831
JAE
Trader Rating: 30 (100%+)
What's everyone's ideal stroke length? With medium Rod ends on the front on outer hole on arm. The arms are basically flat with kit stroke (20mm). I had mistakenly been runnin the inner hole but car is a little darty however had more droop. Running super hi bite clay race this weekend with some flat landing jumps
Originally Posted by oPAULo
Oh I agree and I'm a huge fan of all of them but you can't deny that Kyosho's presence in 1/10 scale offroad in the USA is lacking.
You know how kids are. They want to be like the cool kids. They buy what the cool kids have. Cody King is our only cool kid in the top 25 and he's a 1/8 scale specialist.
Tebo is my favorite driver but it's partly because I'm also a dad and not a cool kid....
JAE is offline
Old 10-19-2016, 07:35 AM
  #13832
Brit_racer's Avatar
Trader Rating: 198 (100%+)
Got my Rb6.6 finished and painted in a Tebo style.
Brit_racer is offline
Old 10-19-2016, 10:52 AM
  #13833
khartlauer's Avatar
Hey guys,
So its been awhile, haven't raced in over a year. My local track has converted to carpet in my time away. I came back to the track with a completely obsolete car. I learned that Kyosho released a new update with the laydown transmission and everyone said I needed it. So I ordered and then when I got the case yesterday, the case is super warped. I put it all together and when I tighten the case together, I have extreme binding problems. Is this the case or could it be something else? I backed out all the screws and the binding lessened but it still has binding issues? Should I replace the case or is there something else that could be going on?
khartlauer is offline
Old 10-19-2016, 11:20 AM
  #13834
tobamiester's Avatar
Trader Rating: 360 (100%+)
Originally Posted by khartlauer
Hey guys,
Not sure about 'super' warped but most people have reported some warping in the plastics which appears to be normal. Most folks built them and had no issues.
i've built 3 laydown tranny's now and all warped. One of them was indeed binding. I took it apart and rebuilt it. Then ran it for a few mins on the bench with a motor attached and it was good.
tobamiester is offline
Old 10-19-2016, 11:24 AM
  #13835
khartlauer's Avatar
Awesome, I asked one of my buddies who knows his stuff, and he said to rebuild it and run it. He said some times new transmissions need to "break in". The idler, case, and diff are all new. Did you tighten the case together completely or did you back out the screws a little?
Old 10-19-2016, 11:30 AM
  #13836
After rebuilding it, i tightened it up. It felt free enough to run/break-in.
Old 10-19-2016, 01:07 PM
  #13837
Very informative information about laydown trasmisison, I will build my new b6.6 for Xmas :-)
lynx75 is offline
Old 10-19-2016, 05:06 PM
  #13838
oPAULo's Avatar
Just got my laydown 3 gear built. It was warped like all the others but it closed right up and spins very free. All screws good and snug. So nice.
oPAULo is offline
Old 10-19-2016, 07:11 PM
  #13839
oPAULo's Avatar
Haven't heard it mentioned but there's 3 options for mounting the rear tower with a laydown transmission.
oPAULo is offline
Old 10-25-2016, 05:12 AM
  #13840
Trader Rating: 166 (100%+)
To run shocks all the way out on arms you need LA43 5.8mm ball ends to get proper droop, same as whats needed with Tebos tower. Any reason you want to run your front shocks that stiff?
jpcopeland1 is offline
Old 10-25-2016, 08:17 AM
  #13841
JAE
I believe that was just the kit setup on the buggy with medium for ends, along with short links (outer hole on tower) on the front. Moved shocks in on the arm and car became darty and traction rolled easier on sweepers so reverted back to the outer hole which helped. Just noticed very little droop. Buggy drives great though. Driver needs some help...I
JAE is offline
Old 10-30-2016, 11:22 AM
  #13842
oPAULo's Avatar
Kiddo and I finally got to run our 6.6's Friday and Saturday and WOW! What a difference. We kept our 6.0's pretty tight and fresh so I know the difference is more than just that new kit feeling. I will say however that our old shock shafts had some wear. The build went smooth. Being a machinist, I really appreciate Japanese precision. I built one shock with the red kit seals and one with the clear X-ring seals and that is a HUGE difference in drag. Very noticeable. The clear X-rings are butter. I don't know why they don't just put them in the box. We built his 4 gear laydown and mine 3 gear just to feel the difference. The 4 gear seemed to be better with mod motors. Our tracks tend to go dry dusty by the end of the night so I ran the rear tower all the way back and cut the tabs off the waterfall to get the battery all the way back. I also run aluminum posts instead of the backwards battery holder to clean it up and gain more room for electronics. I use the factory holes in the chassis and heat and bend the strap a shade so it fits. Really simple and clean setup. With no titanium and full size servo and speed control and aluminum pucks it weighs 1565. Might try 2.4 wheels and see what that does but I'm happy with it.
oPAULo is offline
Old 10-31-2016, 03:09 AM
  #13843
eper's Avatar
Trader Rating: 14 (100%+)
Looks good
eper is offline
Old 11-01-2016, 07:59 AM
  #13844
jrz93's Avatar
whats good starting point for 17.5? 72/30? and will ae spurs work as all my lhs have?
jrz93 is offline
Old 11-01-2016, 08:11 AM
  #13845
dmatter's Avatar
Kyosho using bleeder caps on the new cars?
dmatter is offline
