Kyosho Ultima RB6 & RB6.6 Car Thread
Dumb question. Moved upper camber link to the middle of bulkhead was outside will I have to adjust lower tierods also. Can't seem to get it centered back up .
What does running a Medium vs. Large ball end type on the front/rear shock do for handling besides moving the shock collar up and down the shock body for a given ride height? I see Tebo is running L fronts and M rears which is the opposite of what the manual specifies. I presume it has something to do with vertical travel?
It does change suspension travel though. It actually reduces the vertical travel to 19mm from roughly 20mm with the medium eyelets.
Super Moderator
So this might seem a little overboard but has anyone measured and did the math on the angles the rear toe blocks provide? After googleing right angle trig (because it's been a while) I did the measurements and came up to 2.7* on the toe blocks without the pills. Then I did the measurements on B in/A and came to 3.2*. Technically speaking, what I thought was 3.5* is closer to 3* than the included spec sheet says. Anyone took the time to measure and calculate?
So my mid motor will show up on Thursday "BUT" found a local guy selling a newly built rear motor complete with Tekin Gen 2 ESC, Gen 2 10.5 motor, Spektrum 6040 servo, many aluminum and carbon upgrades too from Kyosho, Lunsford and Exotek. Seems nothing is stock on this thing, ready to run with hardly a scratch and a huge parts bag all for a whopping $330!
So by Thursday I will have 2 like new 'ready to run' cars, one mid motor one rear all for $680. I will try them both and sell the one I don't want!
I did the same measurements with the kick up and I'm getting a little over 2* with the half millimeter shims. I not an engineer so I may be doing something wrong but some of this makes sense when compared to other cars. After a local fast guy told me that a different manufacturer accidentally thought something was 3* when the actual cad drawing proved 2.6*, I thought I would try measuring my stuff just to double check.
Super Moderator
I think in the long run that when you find something that works on your car as good as it is now, you will write it down. Then when you try something else and it doesn't work as good you will go back to what you originally wrote down thinking it was 3 degrees rather than installing the parts it would take to get the measured 3 degrees.
Oh, btw, everyone on tech is an engineer. Just a different type.
im pulling all the lightweight stuff out of mine and changing the battery layout. i hated my car at ocrc.
love my mm rb6 at ocrc!
Hi, I have the rtr rb6 I bought last year.ive been upgrading it slowly. Servo, receiver, steering rack, turn buckles, shock caps, body,wing, now motor and esc..going LRP 8.5 and my question is being a gear diff what fluid would you run and any suggestions on slipper? I'm thinking 3 to 4k
I'm gonna run the shorty sideways. I tried inline in my b5m and wasn't a fan. Figured since most people run inline on the rb6 that's what I would start out with. My car was extremely twitchy with a pretty standard ocrc setup for the rb6.
Wouldn't making changes to the cars setup, front tires, etc, be more beneficial than heavily modifying the car?
And the car is under weight so I'm just removing the puck system.
