Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Old 06-24-2014, 06:34 AM
  #10516
KalEl63's Avatar
Zylux I know what you are talking about even though mine comes from RM.
As soon as I changed to 3.5 rear toe the car changed I have also used white and going to give pink a try.
Also I recommend more anti-squat ~2 I did this to my RM and the car felt better again IMO
I ran my MM at our track and felt with these changes it would work on a medium type grip track. I just need to get the hangers to do so
Hope my input sort of helps you
KalEl63 is offline
Old 06-24-2014, 01:53 PM
  #10517
Zylux's Avatar
Originally Posted by mourinho
Zylux - I experienced similar issues with the rear end spinning out on similar track conditions.
The thing that helped the most was loosening the diff, I had it far too tight from when I was running on carpet, then going to hardpack with dust it was all over the place.
Thanks mate, I'll try loosening the diff a little. Diff tightness is one area I'm fairly unclear about in terms of how it should feel on the bench so I may well have it too tight.
Zylux is offline
Old 06-24-2014, 01:57 PM
  #10518
Zylux's Avatar
Great, hopefully the extra 1.5deg of rear toe will improve things. I'll try more anti-squat as well. I have every front and rear spring except for the rear white and pink so that will have to wait. I may try playing with roll centers and shock mounting positions to reduce the relative roll stiffness at the back end in the interim.
Appreciate the help guys!
Zylux is offline
Old 06-24-2014, 07:11 PM
  #10519
Trader Rating: 68 (100%+)
Anyone get those stupid pills stuck in the rear suspension holders. I tried to remove one with and of my hex and ended up putting a hole right threw it. Now I can't get it out. Don't want to spend another 20 bucks on the part
Speedychris22 is offline
Old 06-24-2014, 11:15 PM
  #10520
They sell the pills separately for like 5 bucks. Same thing happened to me too, but i ordered extra pills from the giddy up out of fear of losing them
glenng is offline
Old 06-25-2014, 01:44 AM
  #10521
Gayosaka's Avatar
Just use some grease when inserting them.
Gayosaka is offline
Old 06-26-2014, 07:10 AM
  #10522
Trader Rating: 31 (100%+)
Has anybody confirmed the difference between the RTR chassis and the standard rb6 chassis? Are they the same with different annodizing or are there other differences?
adubaz7 is offline
Old 06-26-2014, 10:52 AM
  #10523
Holmberg418's Avatar
Rtr is stamped I think and kit is milled. They are different different metals as well I believe.
Holmberg418 is offline
Old 06-26-2014, 12:12 PM
  #10524
Trader Rating: 25 (100%+)
I just cant' get on with it. The car drives so much better with the ESC in front of the battery. I have been playing with the ESC between the motor and battery but it's just not working. I'm going back to what works. I feel the car has better steering setup this way. Having the ESC next to the motor I have to add weight to the car which I don't like to get the traction I need. Am I crazy?
chevmaro is offline
Old 06-26-2014, 01:33 PM
  #10525
aloksatoor's Avatar
Trader Rating: 43 (100%+)
Nope right on target from my perspective . I gather ur running a LW chassis? I also run my mid motor with shorty forwards, esc on the rt6 esc shelf, rx behind servo. Leaves enuff room to put a fan in front of the motor as well. Tonnes of steering. I found the car to jump bad with everything near the rear as well .
aloksatoor is offline
Old 06-26-2014, 01:42 PM
  #10526
My car always runs best when I don't try things other people are doing.
chevmaro is offline
Old 06-26-2014, 02:13 PM
  #10527
Zylux's Avatar
Yeah, if you are running out-door medium grip tracks then I think you need the weight as far back as possible. I run my shorty against the motor with a lightweight Tekin ESC in front as well as a KO-Propo shorty servo and I still only have a 38/62% weight distribution - which from what I'm told is still too front heavy for ideal handling on medium grip hard-packed tracks. I may even try the battery across the back of the motor instead of inline to see if I can shift the weight to the rear a bit more.
Zylux is offline
Old 06-26-2014, 08:06 PM
  #10528
Trident69's Avatar
nro, possible to clip a pix of your electronics layout?..
cheers!!
Trident69 is offline
Old 06-27-2014, 08:28 AM
  #10529
K_King's Avatar
Trader Rating: 47 (100%+)
Anyone try red front springs yet? The AE Guys are running red and gold. 1.6s all around.
K_King is offline
Old 06-27-2014, 08:33 AM
  #10530
I run Avid Red Springs. I have a hard time paying 20 bucks for springs. I have been tuning with the Avid's for a while. They are pretty great. I can't seem to find spring rates for any of the Kyosho springs. Avid Red Fronts are 3.3lb and noticeably stiffer then kyo pink.
chevmaro is offline
