Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Old 12-22-2013, 05:32 PM
  #9106
ovalracer1m's Avatar
Trader Rating: 29 (100%+)
Originally Posted by Speedychris22
Kevin I was looking at your latest setup on petit Rc nd noticed your using different pistons, which brand are they?
Can't speak for Kevin, but I would bet they are drilled kyosho blanks. It is what most of the drivers are doing for pistons if they are not the standard 5 hole listed.
ovalracer1m is offline
Old 12-22-2013, 06:58 PM
  #9107
Finished mine.. still gots tape it down and break the diff in a bit more..
Tried a little something different and clean..
iMarky is offline
Old 12-22-2013, 07:37 PM
  #9108
K_King's Avatar
Trader Rating: 47 (100%+)
You can run Losi 55s but I ran blank Kyosho drilled to 55. We now have predrilled pistons in the 4x1.3 and also 3x1.4 and 2x1.6 which provide more initial pack.
I've run both kinds and the 4x1.3s are the best all around for my track which is inconsistent. If you have a track with a lot of grip or pretty big jumps the other holes may help versus having to go up in oil.
K_King is offline
Old 12-22-2013, 08:29 PM
  #9109
Trader Rating: 68 (100%+)
I run at a track that has low traction with lots of bumps what do you think would work? Also when are these pistons coming out for the general public
Speedychris22 is offline
Old 12-22-2013, 08:33 PM
  #9110
skengines's Avatar
Trader Rating: 226 (100%+)
If you can't wait for the Kyosho pistons, I know a lot of guys run GHEA pistons.
http://www.amainhobbies.com/product_...ns-4-4x13-Hole
skengines is offline
Old 12-22-2013, 10:11 PM
  #9111
B00t13g's Avatar
Kyosho America has the new pistons available and I'm sure their distributors will as well.
B00t13g is offline
Old 12-22-2013, 10:49 PM
  #9112
Trader Rating: 50 (100%+)
Ran my mid motor today in stock class. I liked it a lot, but still curious how it would be in rear motor. Thinking of converting it this weekend.
jamesbernatchez is offline
Old 12-23-2013, 01:22 AM
  #9113
I just finished my RB6 tonight too. This was my first Kyosho car and Ive gotta say this kit is pretty darn impressive. I am really excited to go run this thing.
Now I just need to paint up a body and mount up some tires.
I got the insipiration for the electronics layout from David Ronnefolk's car that I saw on Petit.
pwrslider is offline
Old 12-23-2013, 06:58 AM
  #9114
tschenck's Avatar
Trader Rating: 110 (100%+)
James just drive mine, kyles or even paulos to get an idea. Paulos will be the worse one but if it fits your driving style better then yours then change to rear motor. Oh and mount both front tires the same direction.
tschenck is offline
Old 12-23-2013, 10:23 AM
  #9115
nickdawg18's Avatar
Trader Rating: 33 (100%+)
I just bought the v2 0° aluminum rear hubs. Is everyone using the bigger option bearing or the smaller one?
nickdawg18 is offline
Old 12-23-2013, 11:08 AM
  #9116
K_King's Avatar
bigger
K_King is offline
Old 12-23-2013, 07:38 PM
  #9117
nickdawg18's Avatar
bigger
thanks buddy.
Old 12-23-2013, 07:41 PM
  #9118
Holmberg418's Avatar
Run the bigger bearings. They typically last longer and take more abuse from hits on the side wall
Holmberg418 is offline
Old 12-23-2013, 07:42 PM
  #9119
K_King's Avatar
Originally Posted by nickdawg18
thanks buddy.
Smaller will work but they will eventually blow out. The amount of load that is transferred to the bearing on the metal hubs is a lot. I'd only run the small ones in stock where rolling resistance is more of a concern than durability.
K_King is offline
Old 12-24-2013, 03:44 AM
  #9120
Kevin what's ur thought on new chassis? Worthy upgrade?
