Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Old 11-13-2013, 08:01 AM
  #8626
kyle3333's Avatar
If I wanted a setting in between running flat arms and gull wing arms.
Would running flat arms with medium length shock eyelets be a solution? In other words, would creating more droop with the flat arms create a middle ground between flat and gull wing?
I'm curious for either MM or RM configurations.
Thanks.
kyle3333 is offline
Old 11-13-2013, 08:04 AM
  #8627
MikeXray's Avatar
Trader Rating: 73 (100%+)
Thanks.
The eyelet difference is there to get to the same droop level between the 2 arms, this car runs little droop as it is, I don't imagine you would want to run less.
MikeXray is offline
Old 11-13-2013, 08:26 AM
  #8628
kyle3333's Avatar
I always thought that the flat arms with short eyelets took some droop away compared to the standard kit gull wing setup.
Whether that is the case or not, wouldn't I be adding more droop by using the medium eyelets with the flat arms? In theory creating a middle ground between the two rear arm configurations.
kyle3333 is offline
Old 11-13-2013, 08:27 AM
  #8629
Razathorn's Avatar
Honestly, I don't understand why anyone runs the gull wing arms. I liked them way better even in low traction conditions because it just made the car feel right. It felt really lazy in the rear with the gull wing arms.
Razathorn is offline
Old 11-13-2013, 09:06 AM
  #8630
What up?'s Avatar
Trader Rating: 14 (100%+)
Raz,
Its personal preference for sure but I like the straight arms on the rear motor car and the gull wing arms on the MM set up.
What up? is offline
Old 11-13-2013, 04:43 PM
  #8631
ovalracer1m's Avatar
Trader Rating: 29 (100%+)
Originally Posted by Jochim_18
MM SETUP FOR LOW TO MEDIUM TRACTION WET TRACK
Here what's I have been running at my local track... You can't use setup on a track that have traction with MM buggy more than likely you are not gonna have forward bite when you run the same setup on a track that have low traction. I have been running MM since the losi 22 came out and learn a lot how to properly setup a MM buggy.. I got the base setup posted at petit rc for kyosho RB6..
For those of you that have tried this setup, what rear springs are you using? I dont see that avid makes a purple rear spring? Just a front purple 3.61 rate. My guess is that the setup sheet shows the springs between front and rear reversed. So white rear, purple front....Looking at the pistons and oils listed, that has to be the case
ovalracer1m is offline
Old 11-13-2013, 07:43 PM
  #8632
Oasis's Avatar
Trader Rating: 38 (100%+)
I have actually driven Kim's car....and it's pretty dialed..reminded me of driving a touring car..I just got an RB6 and I'm going to start with RM..but his set up is good..
Oasis is offline
Old 11-13-2013, 09:37 PM
  #8633
rpboggs1's Avatar
Trader Rating: 19 (100%+)
Originally Posted by kenny lutz
I just switched to mm and I was I spaced the rear hinge pin holder 2mm up. So should I raise the tranny up 1mm or 2mm? Thanks for the help
I was wondering this too... Any suggestions?
rpboggs1 is offline
Old 11-14-2013, 07:51 AM
  #8634
thank you for the insight, looks like a decent starting point MM. Our track is med/high bite and very tight. Just noticed the sheet has the springs switched around but got that figured out. thanks
Old 11-14-2013, 08:20 AM
  #8635
bigemike's Avatar
Trader Rating: 36 (100%+)
does anyone have a reccomendation on a starting setup for mm and also do I need anything that doesn't come in the kit to set it up properly. I have it is rear motor now with the older style alum rear hangers and the v2 hubs 0 degree
bigemike is offline
Old 11-14-2013, 09:54 AM
  #8636
MikeXray's Avatar
Best resource for setups:
http://www.petitrc.com/setup/kyosho/...UltimaRB6.html
Seems that the Tebo setups are the best to start from:
http://www.petitrc.com/setup/kyosho/...sic2013031517/
If you don't have Rb5 UM521 arms, the rest of the setup applies, but you need to run a longer shock end on the rear, and thicker rear shock oil.
MikeXray is offline
Old 11-14-2013, 11:29 AM
  #8637
MikeXray's Avatar
Kevin was asking about the knuckle spacer in relation to caster: found this http://www.petitrc.com/setup/kyosho/...dAckermanMath/
MikeXray is offline
Old 11-14-2013, 11:57 AM
  #8638
K_King's Avatar
Trader Rating: 47 (100%+)
I ran the gulls last night again in my MM car. The car is SO soft with them on there. I run 2x1.6, White spring, Losi 27.5wt with a car that is 1560 and I was nose jumping like crazy. I went back to the flat arms and the car felt way better, especially jumping. I dont know if you need even weight or just at least 30wt in the rear, but I normally run 25/27.5 and 30 or 32.5 front. It was stupid how bad it made my car.
Bleh
K_King is offline
Old 11-14-2013, 02:45 PM
  #8639
Default RB6 Setup
Hey fellas, I just wanted to post a setup on 2wdMod.com that was ran by Kyosho/ Team Orion driver, Andy Dibrino. His car was absolutely dialed all weekend. Give it a try and see if you like it. Of course...get the right tires on and adjust ballstud height accordingly.
http://2wdmod.com/2013/11/14/2wd-clo...winning-setup/
sir_thomas is offline
Old 11-14-2013, 05:40 PM
  #8640
bigemike's Avatar
I see he is running a saddle pack, would the setup work with a shorty or are saddle packs better for mid motor?
bigemike is offline
