Kyosho Ultima RB6 & RB6.6 Car Thread
#7846
Just measured wheelbase on my rb5 wc and comes to 298 mm. What is the wheelbase for rb6?
#7847
Correction on rb5 wc wheelbase its 273 mm
#7848
Super Moderator
From Kyosho America's website the wheelbase is measured at 285mm. Of course you can change the wheelbase on both cars so consider that factor.
They also state the following: Long Wheelbase The chassis is now 13mm longer than the original RB5, giving you amazing stability.
#7850
Hey guys maybe somebody can help me. I have a RB6 that I bought used set up in the rear motor configuration and I want to try a mid motor set up. Is there a parts list with part numbers somewhere or could someone let me know what I need to get to do the conversion? I don't have a manual if its listed in there.
#7851
http://www.kyosho.com/jpn/support/in...IMA_RB6_IM.pdf
Exploded view
http://www.kyosho.com/jpn/support/in...IMA_RB6_EX.pdf
Parts list
http://www.kyosho.com/jpn/support/in...A_RB6_SPOP.pdf
For MM all you need is:
Rear Tower
MM transmission case
Extra idler gear (2 bearings, and the aluminum rod)
Motor guard
Rear bumper mount
Rear bulkhead
Rear wing mounts
The rest you already have in RM config.
#7855
I didnt change anything from going to rear to mid motor. I just dropped the ride height cause I was running the mid motor on carpet and changed the tires
#7858
Swapping my rb6 over to mod for the first time and I seem to have lost the plastic washers that hold the spring centered, will these work with the stock slipper plates? http://www.amainhobbies.com/product_...per-Spring-Set
#7859
I ran my rb6 for the first time today broke my a-arm mounts on my first batt but on the second things went much better so far I'm liking the car but the only change I have made other than longer front camber links is I'm running losi #54 pistons all around with 30/27.5 and my car lands great and feels plush. going to work more on the setup on my next outing but so far the car is great can't wait to really tune her up.
#7860
