Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Old 06-13-2013, 01:40 AM
  #7231
aloksatoor's Avatar
Trader Rating: 43 (100%+)
Originally Posted by mikeyscott
Yes
Inconsistent
Mine seemed very lazy. It just did not want to break traction din't spend too much time on the setup though. Let us know when u get the kit for fit and finish.
aloksatoor is offline
Old 06-13-2013, 01:43 AM
  #7232
Have owed a vega rb5 and db1. Wish I'd kept these over the RB6
mikeyscott is offline
Old 06-13-2013, 07:04 AM
  #7233
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
My mm setup was badass but the rear configuration was easier for me to drive fast. If we had just a little more traction at my track... I woul have stayed mm. We have more than enough for rear motor however
ryanpatrickgore is offline
Old 06-13-2013, 10:57 AM
  #7234
CanyonCarverR1's Avatar
Anybody remember how long it took kits to become available after the first prototype was spotted?
CanyonCarverR1 is offline
Old 06-13-2013, 11:05 AM
  #7235
pekow91's Avatar
Trader Rating: 45 (100%+)
Originally Posted by justpoet
Wide vs narrow rear holders, do the narrow ones also help with on power rear traction AFTER the turn is completed? That's where I've typically wanted more traction when I ran my RB5 and tested a friend's car (I'm decent with my finger, but would like to be able to push harder once squared up).
I run the narrow holders and I seem to get better rear traction than the wide ones. I believe you run at NorCal Hobbies (noticed the same handle as the youtube videos of the club races). I should be out there on Sunday if you want to check mine out.
pekow91 is offline
Old 06-13-2013, 11:20 AM
  #7236
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
I thought it was a month or two.
Keep in mind that just because you saw a prototype doesn't mean they will release the car. Associated ran prototype cars at the World's in the early 90's (if I remember correctly) but they didn't see production.
Kraig is offline
Old 06-13-2013, 11:34 AM
  #7237
aloksatoor's Avatar
Is this about the zx6 or a new rb6?
Old 06-13-2013, 11:41 AM
  #7238
pekow91's Avatar
I assume a ZX6 since there was some photos of Tebo with a 4wd buggy with an aluminum chassis.
pekow91 is offline
Old 06-13-2013, 01:40 PM
  #7239
Super Moderator
Kraig's Avatar
The RB6 is what I was thinking because we knew 100% sure that it existed after the race at Hot Rod Hobbies. A month or two after, I thought we were able to get our hands on them.
I am guessing the same logic wants to be applied to the new 4wd buggy Tebo raced a week ago. But I wouldn't count on it coming out before the world's because if they win the worlds with the new car just imagine the advertising campaign after the event.
Kraig is offline
Old 06-13-2013, 02:07 PM
  #7240
aloksatoor's Avatar
Yeah think it will be around that time sept or so when the indoor season gears up mostly . Anyways glad the wheeler class is coming back full force. Cars also seems a lot tougher, we get 2 full heats on club nights and most of them complete the races.
Old 06-13-2013, 04:54 PM
  #7241
skengines's Avatar
Trader Rating: 226 (100%+)
I'm install the Triad slipper on my RB6.
It says to not use the supplied washer but to use a thin one, but I don't see a thin washer supplied.
Can anyone help please?
skengines is offline
Old 06-13-2013, 06:37 PM
  #7242
Trader Rating: 68 (100%+)
It comes with the top shaft
Speedychris22 is offline
Old 06-13-2013, 08:04 PM
  #7243
Greg Etter's Avatar
Looking for a little help. I'm using a savox sc 1251 servo and would like some reassurance that I used the correct servo spacer shim. For those that have used this combo which should I be using?
Thanks.....Greg.
Greg Etter is offline
Old 06-13-2013, 08:10 PM
  #7244
justpoet's Avatar
Trader Rating: 16 (100%+)
Thumbs up
Sounds good, look for the guy with the Apple hat.
justpoet is offline
Old 06-13-2013, 08:32 PM
  #7245
mdowney's Avatar
Trader Rating: 21 (100%+)
To expand... you need to purchase the Avid top shaft for the RB6 in order to use the Triad slipper.
mdowney is offline
