Kyosho Ultima RB6 & RB6.6 Car Thread
#6706
Sorry to dig up old old postings but I am looking at the Reventon Pro for my RB6 and I had a question about reliability and ease of programming. Is it the same as the other manufacturers in ease of use, or does it take some tweaking? What motor do you run with it? Any comparisons would be greatly appreciated.
I've not had any heat issues or anything negative. Yes the size is marginally bigger than some others but the switch is built in. If you included the size of external switches with the foot print of others you will have about the same overall foot print.
But really the performance of the the SP vs Orion vs something else are all very close. Pick the one you like and go with it and learn it well. They all have their negatives,
#6709
I don't know about the revention pro but I just tried a lrp in my buggy, and loved it so much that I bought another one for my truck! The smoothest Esc I've ever used out of tekin, viper and orca. And the easiest to program. Honestly didn't change any of the settings out if the box except for break.
Someday I will try Orion/Hobbywing but not right now
Raced the car in rear motor config last night and it was great. I could get on power sooner and harder out of the corner. Beat my fastest lap time of all and bumped into the a-main. I am stoked! Going to stay with rear motor for a while this time. I need to tune and get this car faster and a bit more stable in the sweeper. Other than that it feels great. Im Back to the b.collins setup.
#6710
#6711
Looks like this will help with a replaceable insert.
#6712
I don't have any secret insight to what I said, I just know that Kyosho has used bushings in the past and cleary researching them, you can see what they are moving towards. I know that the TKI3 uses blue bearing holders and they hold up great. They just hold the bearing so there is not much going on there that can cause wearing. At least I don't think so. I can promise this, if Kyosho made it, it will work...
#6713
I don't like the idea of having to maintain yet another part of the car but if the alum hubs develop slop then the replacement plastic tree is welcomed. Cheers,
#6714
Hmm this is a step in the right direction I suppose. The xray cars also have plastic bushings in the aluminum hubs front and rear. I have never had them wear out. The wear part is always the bearing which gets gritty. They have a support part at the end whic is just bushings so I am assuming it will be cheap to keep it in tip top shape..
#6716
#6717
Super Moderator
Could a rear hub similar to this handle inserts in the lower hinge pin to handle different degree's of toe? Similar to how you can change the front hubs caster angle.
#6718
A few mins of searching allowed me to find this pic of the new rear hubs.
Attachment 1065802
http://kyoshoshop-online.com/kyosho/...&ggcd=UMW704-0
Attachment 1065802
#6719
Try putting the RF block in the front for Mid motor and keep the RR2, it will give you 4deg toe inboard no more alloy hubs. Just try it, it doesn't take long and let me know how it went
