Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Old 04-15-2013, 07:30 AM
  #6211
teeforb's Avatar
Trader Rating: 94 (100%+)
Originally Posted by C_Money
Yes sir it is
Thank you sir!
teeforb is offline
Old 04-15-2013, 08:36 AM
  #6212
MikeXray's Avatar
Trader Rating: 73 (100%+)
Love this car, was able to TQ 13.5 open with a 17.5 boosted, messed up my start, and got back up to 2nd I couldn't put a run together in 17.5 blinky and ended up in the B, but the car was there, only changed tires all day! I'm going to try out mid motor, the indoor season is pretty much done, can't hurt to try it now.
MikeXray is offline
Old 04-15-2013, 08:58 AM
  #6213
How much boost do you run? And do you change your gearing?
Jetboat_Jake is offline
Old 04-15-2013, 09:12 AM
  #6214
MikeXray's Avatar
Since I was double running the car, I just guessed, I have an SXX TC spec, put it on boost profile 7 and dropped 3 teeth, felt pretty good.
MikeXray is offline
Old 04-15-2013, 10:03 AM
  #6215
joeymdz's Avatar
Originally Posted by sir_thomas
I know mid motor is super hot right now, but I've been working on a setup for the rear motor RB6 that uses ALL RB6 PARTS. I'm tired of buying old gen car parts to put on my new car so I came up with this with the help of my buddy Shaun.
I don't feel that the 521-1 are faster than the RB6 arms...maybe they feel easier to drive, but slower on the clock for the most part.
Try the whole setup and let me know what you guys think. Adjust ballstud washers accordingly to your tire and grip level. Rear shock length is off the top of my head, but basically all the way up with the longest shock bottom.
Feel free to ask questions if you have em.
Thomas
good job on the setup Thomas. lots of corner speed, great traction all around, very easy to drive!
joeymdz is offline
Old 04-15-2013, 11:23 AM
  #6216
Trader Rating: 68 (100%+)
Where can I get this setup
Speedychris22 is offline
Old 04-15-2013, 11:43 AM
  #6217
kyle3333's Avatar
What do the narrow lower suspension holders do vs. the wide lower suspension holders?
kyle3333 is offline
Old 04-15-2013, 12:01 PM
  #6218
X2
Old 04-15-2013, 12:06 PM
  #6219
B00t13g's Avatar
What's your track like? Motor?
B00t13g is offline
Old 04-15-2013, 12:59 PM
  #6220
Cpt.America's Avatar
Trader Rating: 52 (100%+)
post #1
Cpt.America is offline
Old 04-15-2013, 05:36 PM
  #6221
jkirkwood's Avatar
Are the plastic rear wide suspension hangers available without buying a transmission case for rear motor configuration? Thanks.
jkirkwood is offline
Old 04-15-2013, 05:39 PM
  #6222
silvalis's Avatar
Trader Rating: 29 (100%+)
Anyone running blinky MM on outdoor hardpack low bite/loose?
Thinking about trying it on wet hardpack w/ loose top... Maybe a bad idea?
silvalis is offline
Old 04-15-2013, 06:56 PM
  #6223
carcrusher46's Avatar
Trader Rating: 17 (100%+)
Nice RB6 w/lots of spares and tires for sale:
http://www.rctech.net/forum/r-c-item...rts-tires.html
carcrusher46 is offline
Old 04-15-2013, 07:02 PM
  #6224
joeymdz's Avatar
Thomas trans setup
http://www.rctech.net/forum/electric...l#post12001505
med/high traction.. Depends.. Lol
motor im using is a vst 8.5 geared at 22/76 with an r10 punch at 3
joeymdz is offline
Old 04-15-2013, 09:00 PM
  #6225
Slimsh8t's Avatar
Trader Rating: 39 (100%+)
Default WTB RB6
Just thought I would post up that I'm looking for one.
Thx,
Kevin
Slimsh8t is offline
