Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Old 11-21-2012, 11:43 AM
  #2746
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
Originally Posted by desertracerdad
Team tidbit... Buy the Carbon Composite gearbox (UMW504C). They are manufactured with more carbon/glass (to be stiffer), there is less shrink and the tolerances are better which allow the tranny & gears to run smoother.
With the new wing mounts on the 6 going through the tranny case I don't recall seeing this on this particular case. So my question is how are you making this work?
Kraig is offline
Old 11-21-2012, 11:48 AM
  #2747
racer x 1's Avatar
Trader Rating: 27 (100%+)
Originally Posted by goin2drt
I have blue accessories.
Thats two of us lol! I grabbed the shocktower and will wait for the rest of the blk parts to come in.
racer x 1 is offline
Old 11-21-2012, 12:19 PM
  #2748
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
Originally Posted by Cpt.America
I had no idea the new AE pistons were two hole pistons... What sized holes? they must be 54s or 53s!
Their box setup is 1.6mm 2 hole 35f, 30r I believe. Drill size is about a #52.
Yeti AS3 is offline
Old 11-21-2012, 12:27 PM
  #2749
Cpt.America's Avatar
Trader Rating: 52 (100%+)
Originally Posted by Yeti AS3
Their box setup is 1.6mm 2 hole 35f, 30r I believe. Drill size is almost a #52.
hhm.. i can't imagine they would be generating any pack with that setup at all.
Cpt.America is offline
Old 11-21-2012, 01:14 PM
  #2750
I mainly run my 6 mid motor and on carpet with big jumps but can't wait to try it on dirt/rear motor.
I tried Ghea pistons and loved them but so far 2x1.4/3x1.3 was mainly for smooth tracks with hard landings, I wouldn't use that much pack on bumpy tracks, more something like 4 holes.
mojo tom is offline
Old 11-21-2012, 01:43 PM
  #2751
cnelson3's Avatar
Trader Rating: 66 (100%+)
It's not all about "pack". The ae guys took their time with the big bores and did them right. U don't see anyone gluing holes shut like tebo did when the bb's came out for the rb5. There is a little room for improvement.
cnelson3 is offline
Old 11-21-2012, 01:46 PM
  #2752
Trader Rating: 101 (99%+)
The new UMW 504C gearbox does have the wing mount screw hole molded into it. The older UMW 504B gear cases we used on RB5/RT5 do not...
desertracerdad is offline
Old 11-21-2012, 01:51 PM
  #2753
So what other factors do you have when you compare or change number of holes, size of holes, and oil weight? You have static damping, (slow movement) and pack (fast movement). What else is there?
Old 11-21-2012, 02:19 PM
  #2754
JPKinsella's Avatar
Trader Rating: 30 (100%+)
Originally Posted by jpcopeland1
I will be there tomorrow as well. Want to go the 4 hole 1.3mm route.
Originally Posted by aloksatoor
Go for it (By it I mean the excellent ghea pistons for the k cars absolute has them with 2 buck shipping). Found it awesome vs the stocks for handling and the cars super reactive as well but pillowy on the rougher stuff. I run pink/gold with 425/375. This was for a 60 plus day though, will go lighter in the winter arena when its colder a month from now.
Did a little testing yesterday with the Ghea pistons 4x1.3 ended up running the tapper down towards bottom of shock little more pack with faster rebound than with the tapper up or a flat Losi piston... Worked really good especialy for mod!! Ended up with losi 32.5wt up front 25wt in the rear white fronts reds rear....
JPKinsella is offline
Old 11-21-2012, 02:36 PM
  #2755
aloksatoor's Avatar
Trader Rating: 43 (100%+)
Think I ran mine taper down as well, oils pretty close as well I went a bit higher in the rear though. Car is pillowy and on rails . Full pack testing this weekend hopefully if the weather holds! Can't wait to get a full prac day in with the car only raced two days still
aloksatoor is offline
Old 11-21-2012, 04:31 PM
  #2756
Trader Rating: 50 (98%+)
the ae pistons are 1.5, 1.6 1.7 all 2 hole.
micrors4guy is offline
Old 11-21-2012, 05:02 PM
  #2757
Trader Rating: 90 (100%+)
1.3 would be closest to 55's, but it's NOT that size.
Kuya_Kimo is offline
Old 11-21-2012, 05:17 PM
  #2758
cnelson3's Avatar
Where do they sell these? Is the whole piston tapered or just the wholes?
cnelson3 is offline
Old 11-22-2012, 11:19 AM
  #2759
Happy Thanksgiving to all my fellow members of the Red Army!
Old 11-22-2012, 11:39 AM
  #2760
Moderator
Posvar's Avatar
Trader Rating: 470 (100%+)
Thanks Brandon! You too!
Posvar is offline
