Kyosho Ultima RB6 & RB6.6 Car Thread >
Like Tree172Likes
    Hide Wikipost
R/C Tech ForumsThread Wiki: Kyosho Ultima RB6 & RB6.6 Car Thread
Last edit by: tobamiester
MSRP $639 MAP $399.99
Chassis:
Battery Holder:
Rear Bulkheads:
    • MM3 bulkhead
    • Laydown bulkhead
    • Swaybar Holders
    • transmission cases
    • spacers
    • caps
  2. Gear Cover - UM735 - $6.99
    • spacers
    • caps
    • required extra hardware
    • pastic FR suspension hanger
  2. 40T idler - UM737 - $6.99
  4. Gear cover - UM739 - $6.99
Body:
Optional Parts:
UMW704-0 V2 Aluminum Rear Hub Set(0°/RB6)
Nice to have:
Aftermarket Parts:
Print Wikipost
Old 11-19-2012, 08:55 PM
  #2686
OnRDPassion's Avatar
Trader Rating: 59 (100%+)
Originally Posted by fastestwon
look at the thrust assembly
Checked the thrust assembly and it was fine. Any other ideas? Is it possible it might be a little tight and with a slow run on it, it will free up the tranny?
OnRDPassion is offline
Old 11-19-2012, 09:10 PM
  #2687
B00t13g's Avatar
Picking mine up Friday!!!
B00t13g is offline
Old 11-19-2012, 09:19 PM
  #2688
Yeti AS3's Avatar
Trader Rating: 77 (100%+)
Originally Posted by cnelson3
i'm kind of interested in the 2 hole piston idea. are you just running those in the rear or the front as well... what do they do in comparison to the 55's or k-55's?
Just on the rear. Comparing 55's w/27.5 to the 2 hole w/27.5 they feel about the same on the bench but the car recovers super quick on landings. When not landing perfect it just soaks it up and goes. The rear felt a little slow on the bench so I went to 25wt. It obviously has a little less pack but I still like it better. My new ones are 1.55 holes which I will try with 25 as well. At LHR it helps A LOT with the larger jumps. I dont feel it affected traction o.e way or the other compared to 55s.
Yeti AS3 is offline
Old 11-19-2012, 09:26 PM
  #2689
CanyonCarverR1's Avatar
Originally Posted by OnRDPassion
I am going through my car again and i noticed some gear grinding in the gear box. I thought that maybe I was a little heavy on grease on the gears so i pulled it apart and built it again. I then put it together three times now and I still have gear grinding. Has anyone else run into this or have any ideas of what it might be? I also checked the gears and cleaned all of them to make sure there was nothing stuck in the teeth.
For clarification, is it in the diff, like when you hold one outdrive and spin the other? Or is it something with the gears?
CanyonCarverR1 is offline
Old 11-19-2012, 09:43 PM
  #2690
fastestwon's Avatar
Trader Rating: 15 (94%+)
another thing to look at is make sure you do not over tighten the transmission case screws . it can cause it to bind the gears
fastestwon is offline
Old 11-19-2012, 10:19 PM
  #2691
It is in the gears. The diff is totally fine and smooth as butter, btw one of the easiest diffs I have built. I made sure the transmission case screws ware not over tightened checked to make sure all the bearings were seated correctly. Totally stumping me.
Old 11-19-2012, 10:38 PM
  #2692
When I first built my car, there was some flashing on the inside of the middle gear. When the bearing was pressed in, it deformed the gear enough to cause some resistance. I know you've already had your car running, and this is a new problem. But check that your bearings are in straight. Its a longshot but you never know.
Old 11-20-2012, 12:04 AM
  #2693
silvalis's Avatar
Trader Rating: 29 (100%+)
What if you took the transmission apart, take the alu topshaft out, put the diff halves back together but dont screw em down, then spin the diff?
Then retry with the topshaft in/spur out
Then retry with all three in but not bolted down.
silvalis is offline
Old 11-20-2012, 02:45 AM
  #2694
eper's Avatar
Trader Rating: 14 (100%+)
i found that a little bit of white gear dust is the norm for my kyosho tranny. everytime i have pulled one apart there seems to be a light dust coating thats why i usually just replace all the gears and bearings during a rebuild.
eper is offline
Old 11-20-2012, 05:47 AM
  #2695
Johnn27's Avatar
Trader Rating: 89 (100%+)
Questions?? pistons
Would'nt just going with a smaller "56" piston in the rear have the same effect?
Johnn27 is offline
Old 11-20-2012, 06:41 AM
  #2696
Trader Rating: 58 (100%+)
Yeti, I noticed in your signature Leisure Hours. This past weekend was my first time running there, should be in town for the next year or so. I didn't notice any other Kyosho's. If you get the chance in the next few weekends PM me, I'd like to pick your brain, Ron.
yokeman is offline
Old 11-20-2012, 08:49 AM
  #2697
Trader Rating: 166 (100%+)
I have a set of blanks I want to try something different with. Does it really matter how exact the hole spacings are? I know it can easily be done with a ruler. I just want to get these Losi pistons out of my car. Sour grapes for spending as much as I did on my 22 to only still have it suck for me? you betcha!
jpcopeland1 is offline
Old 11-20-2012, 08:56 AM
  #2698
Trader Rating: 101 (99%+)
John,
The Kyosho blank pistons have 6 divots already in them, which are evenly spaced. Pick your hole(s) opposite each other and drill them out with a 1.3mm (#55) bit and you are set. I will be there tomorrow if you need any other assistance. R'Dub
desertracerdad is offline
Old 11-20-2012, 09:52 AM
  #2699
Cpt.America's Avatar
Trader Rating: 52 (100%+)
A) You aren't supposed to run grease in your gearbox.
B) does this grinding sound happen with the gearbox out of the car? or only when a pinion is running against your spur?
Cpt.America is offline
Old 11-20-2012, 11:03 AM
  #2700
Originally Posted by desertracerdad
John,
I will be there tomorrow as well. Want to go the 4 hole 1.3mm route.
