Standard Foam or Closed Cell
Hello, I will be running on a hard packed, slightly dusty track that generally runs barcodes or double d's in gold compound.
What is really the differnce between standard firm foam and a closed cell insert? How many people out ther run them?
The closed cell insert will generally be firmer than the firmest open cell insert and also won't break down and soften nearly as fast.
Indoor/high-bite = closed cell
Outdoor/dusty/loamy = open cell.
It sounds like your track may fall inbetween so it may be best for you to mount up two sets of the same tires with different inserts and see what works best for you if there is no consensus pick you can get out of the local fast guys.
Another option is 2 stage foam by PL.
