SC10 Thread Part 2
#181
Just got the front axels and such to finish the hex conversion and then my SC10 will be done, Avid steering rack, Avid springs, Avid retainers, full Avid bearing kit (I should be sponsored by Avid by now, right?) and a full screw kit front Trick-Parts. Have to say, truck looks wicked and can't wait to finish building it. Thinking of running Savox servo wired up for HV off the battery... Thoughts?
It will depend on the equipment you run, but running an extra Cap (glitch buster) doesn't hurt.
#182
Hey bone, sent u a pm. It wontg b until fri until I can hit the track. I made up my mind I may will have to make fiff adjustments about the front dumping so much that my rear inner tire lifts up, I dnt wnt to put a sway bar on there I have felt a guys with em on it and man did it numb his steering out way too much for my liking. My trucks have tons of steering and then I drove his its like the thing didn't have pwr steering lol lol. So I may add the washers bck and lower the ride height , test it then mayb make my rear camber to neg 2 deg if I need to make further adjustments. How that sounds , it may solve my prob
#183
#184
Ive ran the Savox servos before with Caps and they are good. I was going to use the KO propo extension that goes between the servo and the RX and wire the red, positive wire directly to the possitive wire off the ESC so that the servo doesnt even get any power from the RX (only the black and white wires would run off the RX). That way, its getting at least 7.4v at all times and shouldnt need a cap
#185
Sounds like something to try. It sounds like you need to find what works for you. I know a few guys who run such crazy setups, but it works for them.
#187
Leaky Gear Diff
Anyone using a sealer to stop their gear diff from leaking? If so, what is the name and how has it performed. Thanks
#189
#190
IMHO, I wouldn't use Losi bb springs if I were you. I spent over $60 to do the conversion (and buy 6 sets of springs), and could never get it to feel anywhere near as good as my F.T. SC10 with the stock springs on it... and my track is the same as the conditions you listed. If you want to go with the big bores, go with the Avid ones (Fronts / Rears). They make them much stiffer then the Losi ones are. I mean, the Avid one's are actually designed to be used on the SC10
#191
Im running the Avid collars and the 22 bottom cups. They are great thus far and loving the springs
#192
I may try em, I have. Several selections of the losi bb and kinda timid to get the avids when I look in my spring box and see that I have a buch od good ones already lol. What avids are u running on high bite indoor clay is it red on all four?
#195
I went with losi bottom, traxas collars, and losi springs, I havent tried it yet. 1.8 in the rear and 3.5 up front. Any one use this?
