LOsi 8ight B 2.0/ Driver/ owner need your help!
Hey guys, I have been having an issue with my 8 making a weird cliking noise when braking! it sounds like a loud "click" when braking from a full throttle speed.I have check all the diff, fron, center and rear, gears are all fine..changed the diff fluid(5,7,3) replace all the drive cups, all the cvds, everything , my car is pretty much overhauled, but it does makes a clicking noise, whats weird is, it only does make noise sometimes!! , if I do it on the concrete(parking lot) it doesnt make that noise from top speed then braking. like I said if i am in the track it does click but only once in awhile, like it will click if she wants to! really weird.about the shimmed issue, I am not sure I did it correctly, I did put 2 shimms both side on center diff.
if you are experiencing same issue or you know how to treat this annoying noise please help.
Thanks,
Allan
Thanks,
Allan
Thanks,
Allan
Thanks,
Allan
EDIT: If it still does it after that try taking away 1 of the shims on the ring side.. or moving it from the ring side to the oppisite side.
YOU need to re-shim your rear diff the 8ight thread has specfic instructions I actually posted something a few weeks ago need to do it right away or you will be buying new gears soon.
