Tekno RC EB48 Thread >
Like Tree2Likes
Old 03-31-2015 | 09:09 AM
  #14506
Jordan Anderson's Avatar
R/C Tech Elite Member
Originally Posted by Seasick78
I've seen some old settings listed on the Tekin site... Wondering if anyone has any good Tekin Esc settings you'd like to share? This is my first Tekin ESC. Running an EB48.2 with RX8 G2 and 1900kv T8 G2 on 17T pinion. Short to medium sized dirt tracks with medium to loose surface.
- Drag brake?
- Brake Strength?
- Timing Profile or advance?
- CL?
- Neutral Width?
I know what each setting controls, just wondering what y'all have had success with.
Ryan Lutz posted an RX8 Gen2 ESC setup on his FB page yesterday. You might want to check it out.
Attached it now...
Jordan Anderson is offline
Old 03-31-2015 | 07:55 PM
  #14507
Originally Posted by Carter Flotron
I usually run 105/121 at most tracks. Although, I usually go up or down front and rear by 1-2mm depending on the track surface.
It really depends what you like. If you like your car to 'run flat' and no shift weight around too much, run less droop. If you like to steering with the throttle and brakes and have lots of weight transfer, more droop is probably going to work better for you.
Thanks for the info I really appreciate the help I think the more droop will suit my driving style.
mod16 is offline
Old 04-03-2015 | 02:17 PM
  #14508
advpball's Avatar
What's everyone running for servos my jr 8717 finally started acting up after 2 years
so deciding on same or new brand?
Thanks in advance
advpball is offline
Old 04-03-2015 | 02:47 PM
  #14509
Cappy's Avatar
Few guys around here are running the Savox HV servos and Liking them.. Im still running the 1256TG and not having a problem
Cappy is offline
Old 04-03-2015 | 03:25 PM
  #14510
I'm running a radiopost rp5005s, svaox 1283sg, & savox 1268sg in my tekno's.
RP & 1283 are not in anything at the moment due to waiting for my new .3 sct.
ezlight is offline
Old 04-03-2015 | 05:38 PM
  #14511
mkl
SCT410- Spektrum 6090
EB48- Spektrum 6100
ET48- Protek 170S
All have been working flawlessly.
mkl is offline
Old 04-03-2015 | 08:13 PM
  #14512
Mizchief's Avatar
I like my Savox HV's (see sig) Tried a Protek for the first time in my XB4 and it's been awesome so far. Stupid fast and strong for a low-profile, but haven't had it long enough to talk about durability.
Mizchief is offline
Old 04-04-2015 | 06:07 AM
  #14513
I have a small army of HS-7955TG throughout my vehicles. Incredibly reliable, I have yet to strip a gear, are rated for high voltage, and universally fast/powerful enough for my needs with both steering and throttle.
RokleM is offline
Old 04-04-2015 | 06:25 AM
  #14514
advpball's Avatar
ok spectrum 6100 or hitec 7955 so are the servo wires long enough or do you need extension wires?
advpball is offline
Old 04-04-2015 | 06:37 AM
  #14515
7955 yes, can't comment on the spectrum.
RokleM is offline
Old 04-04-2015 | 06:51 AM
  #14516
Potoczak's Avatar
I had a ace 1015 in the eb48 first then installed a protek servo. Both of them needed extensions. I think most servos you will need an extension.
Potoczak is offline
Old 04-04-2015 | 07:19 AM
  #14517
mkl
Yes, the Spektrum servos need an extension.
mkl is offline
Old 04-04-2015 | 07:40 AM
  #14518
Shawn_S's Avatar
If you want a servo that doesn't need an extension, and budget is no limit, this is the best servo I have ever owned; and I've owned them all. All Radiopost including Signature, Futaba 9352, Savox 1267/8 & 2274, Hitec 7955&7950
http://www.amain.com/rc-helicopters/...ksbl01/p388039
Shawn_S is offline
Old 04-04-2015 | 08:30 AM
  #14519
FastPete's Avatar
That's a nice ride!
FastPete is offline
Old 04-04-2015 | 01:49 PM
  #14520
Potoczak's Avatar
Thanks!! The build as super easy though I'm having an issue with the shocks. It seems the bladders are collapsing under full compression and get sucked into the shock body, then oil starts coming out of the bleed holes. Any tips???
Potoczak is offline
