Tekno RC EB48 Thread
I think they mean to run the whole motor mount/diff carrier/diff section backwards, so the motor hangs to the rear. From memory, I'm not sure there would be enough room where the mech brake servo is meant to go for the eBuggy motor. It might work with sc motors though. It would be tight and need measurement if so, and isn't just a screw change though.
Anyone ever use this stuff or another alternative for silicone grease in bulk vs. paying over a dollar a cc for the stuff from the hobby companies?
http://www.amazon.com/Silicone-Greas...ilicone+grease
What is the description of the stock shock pistion that comes in this car?
Need some help. Under hard braking situations my rear end wants to come around. Should I change my setup to help correct this or just decrease my brake?
From a physics standpoint, an item that is sliding (rear wheels) - like hyrdoplane - has less friction and wants to pass things that have more friction (the front wheels, which aren't). So the rear end comes around. So for setup, you could try to tune your diff fluids, or maybe even droop.
HOWEVER, your front also has about 75% more traction under braking, so at some point your rear end is most likely going to brake free quicker than your front. So you may also have too much brake.
Basically, I have no answer - but your setup and the conditions where this occurs might help get you one!
Is TKR1221 the part number for the washers I would use for the steering stop?
What is the part number for the rear gear box with bigger bearings?
If it has always been like this i would check setup (given that you are at the same track)
If it is something that has developed i would look at the drive train. Make sure none of the outdrives are showing excessive wear and all the bearings/ diffs are working properly.
Anything else, such as diff or shock changes would need the full setup to look at and see if they are reasonable suggestions.
