Tekno RC EB48 Thread
#5671
As Ramos posted in the SCT410 thread we wrapped up the WRL series at CRCRC. Eli and I managed to get EB48’s into the top 5 for the series. I personally had hoped to do a little better in the last race but had a servo fail that pulled hard to the left and wouldn’t turn all the way right for the whole main which made consistent laps on the track a little tough. Eli tq'ed and finished second.
A few weeks ago I finished 2nd overall another NE Ohio series that featured two very different type of tracks. One that used slicks and one that we used full pins outdoor type tires. I won a race at each of the tracks proving the buggy works on any surface.
A lot more Tekno’s have been showing up at the local tracks and it seems that E-Scale is going to be a big class around here this summer, looking forward to it.
Great job guys!!! Way to represent!
#5672
Just finished building my buggy! I'm still waiting on my motor and esc. I hope I get them this week because I'm dying to drive this thing. I went with a plain white body for now. Larry from kustomrcgraphics is painting a body for me but that's gonna take a few weeks at least.
#5673
Well I qualified 2nd in SC yesterday at G`s Raceway in PA. and finished 2nd, the truck was good, but the driver wasn't.
I also ran my EB-48, I qualified 3rd. and Won. The buggy jumped great and turned awesome. I moved the rear hubs all the way forward and took the rear toe to 2.5. With the help of my VP PRO tires I was hooked up and the buggy felt like it was in the track...............on another note I saw another guy running the buggy and he broke a shock tower, have any of you seen this before? I was truly shocked!
Paul Rush
Paul Rush
#5675
Need a recommendation from some of the experienced racers. I'm about to order my buggy and I'd like to order the proper pistons / springs / sway bars for my track at the same time. Rarely does a kit setup work on my track. It's a fairly large outdoor track, very hard packed, very dusty, and rutted something fierce.
I'm not sure what to order since I don't know what comes in the box. Thoughts?
Thanks in advance for the help
#5676
Paul Rush
Paul Rush
#5677
Tech Legend
For springs, you may find a benefit to mirroring Austin Blairs setup. I don't recall if Tekno has the weights the same as he used available, but a variety of manufacturers have springs close to what he used his vehicle. For me, I went Hot Bodies White 60mm springs up front (4.54 lbs-in) and Hot Bodies Blue 76mm springs on the rear (3.53 lbs-in). These fit nice, and are a bit shorter than some other springs out there to get some more ride height adjustment room if needed.
Xray springs in the Grey-Blue Fronts (4.568 lbs) and Blue Rears (3.4831 lbs-in) also work on the buggy. These are what I had originally on, albeit, more expensive.
You may also want to pick up a variety of sway bars as well.
#5679
If I recall correct, I think the vehicle comes with 1.2 x 10 hole pistons? You may find a piston switch can benefit, going to the 1.3 x 8 holes. If Tekno is out of stock, Kyosho white ones fit fine, those are what I am using.
#5681
#5683
has anyone tried a spectrum s8000 steering servo? my savox 1256 took a dump with only 4 packs thru it,something inside let go,first one i have that failed. the spectrum is very tall and i think i will have body interference issues,i have the linkage under the servo horn but im not sure that will work when the alum horn gets installed...
#5684
Subscribing....
#5685
You might want to look at CSI pistons. Another guy on here turned me onto them. I must say i was really surprised how well they were working out. Im running the Blue right now. For springs, I would get them all from pink up honestly. Stock yellow springs worked out at a large outdoor track that sounds like something like yours. Sway bars....got them all and i still run 2.4 rear and bounce 2.2-2.3 up front
