Tekno RC EB48 Thread
#5627
Did your kits come with an addendum and shims for the diff pinion to make sure the set screw sets flat in the notch (or enlarge the notch)?
Should look like this......
http://www.teknorc.com/tekno5/wp-con...ddendum_01.pdf
I did also print a manual from the site and I thought I included ass the addendums in it.
If I'd seen that I would have been wondering where my shims were.
#5628
I'll find out on Sunday if it works.
#5629
(Sorry, I know it is an old post but I took a hiatus and am trying to get caught up.)
#5630
#5631
Yes, the first run of the kit had an O ring that went into the groove on the shock body at the bottom of the shock cap threading. Many tried to put them into the cap, or didn't tighten enough once they were on, etc... Later revisions of the kit simply don't include it and pulled it from the instructions, since it was found to not be required anyway.
#5632
On the Kyosho 1.3 x 8 pistons. Are you guys using the white or black ones? What are the differences?
And anyone running mech brakes? Thoughts?
#5636
They are not 1.3 x 8 all arround!
Front and Rear Pistons have different drills (white one and black one).
Intention for that (different pistons in Front than in Rear) is to use the same shock oil rating in Font and rear.
#5637
Just got a eb48. I had a 811be losi associated
Hoping this baby is the real deal
#5638
Black ones have the holes drilled thru the piston on a weird angle making the actual hole longer. The white are drilled straight thru like normal pistons. They are both tapered style pistons. Dont know what others are using but I in general from what Ive seen most like the conventional hole style white pistons better. But good luck finding them anywhere.... seem to be popular items right now.
#5639
Anybody tried these before?
http://www.ebay.com/itm/121093091667...84.m1438.l2649
More of a bling...
Hope we can get allu hubs ,that would be nice.
More of a bling...
#5640
More of a bling...
More of a bling...
