battery help
260 amps vs 325 amps
Are they the same company (brand)?
Depending on your setup (motor and gearing) you may get more run time from 5k 65c pack. If you are not taxing the system as long as the brand is good the 5800 will get you more run time. Typically you will get more usable cycles from the higher c rated pack. Why not a 6000mah or 6600?
List pack details and you will get a better answer.
