Help with Hobbywing boost settings pls
Helllo,
I have a Xerun 120amp esc running 930 mod software SC10 2WD 2s lipo 9.5T Reedy Sonic at Factory 20 mark for timing 18/84 gearing (AE recomended for 9.5T for a sc10) Does anyone have any experience running this software boosted with simlar motor? What boost and turbo should be a safe maximum? Its running real cold now at 5 deg boost and 5 turbo |
Not sure how much you would really need to boost a 9.5 but I would not run any turbo with that setup. I run that same esc but run zero boost at most tracks. I have added a little on larger outdoor track but was minimal. As far as gearing, I would start with 21/87 and zero boost. Then add a little boost if needed, just make sure to monitor temps. The gearing listed on the AE site is a very conservative starting point.
Boost and Turbo are not meant for nor reccomended in Most Mod motor setups. If your needing more speed you should buy a hotter motor. but If you want to, Just keep adding boost while checking temps, Theres no right and wrong setup, as long as your system is still running within proper temps.
thanks guys, yeah i suppose I just have withdrawal from onroad going to blinky for stock,
I love boost :lol: I love boost in real cars too ;) |
ANY INFO ON A HOBBY WING 120A WITH A SONIC 17.5 IN A SC10
ANY INFO ON A HOBBY WING 120A WITH A SONIC 17.5 IN A SC10 I NEED SOME HELP WITH ESC SETTING AND GEARING. PLEASE HELP
Originally Posted by KMA88
(Post 10532390)
Boost - 75-24-25... Im not sure how boost is on that controller but I would start at like 20 boost at 5000-17000rpm |
(Post 10532390)
sc8 120a help
having trouble getting into set up mode any help?
