CVD Shaft pin removal tool???
I know this have been talked ab out before but I am curious if anyone have any issues with the MUGEN pin removal tool or the King headz Bonesaver? I am planning to buy one as soon as possible but I have no i dea which one works better, the hudy is too expensive but i know it works well and i know its worth it but I dont have enough coin right at this time.
I already replace my cvd/drive shaft about 3 times now and they are expensive.
BTW i have losi 8ight!!
any feedback will be appreciated thank you
super nice guy and im sure he can help you out.
R/C Tech Elite Member
http://www.amainhobbies.com/product_...placement-Tool
I ve this one and love it! It is $99 though...
Suspended
The real solution to this problem would be if the manufactures would just make it so the pin was held in place by a set screw. Sweet Crispy Jesus, I love being so smart.
I had the bone saver type and I recently put it in the garbage. It worked great on durango, mugen and losi for me until I went to use it on associated pins for an rc8be. I broke two bolts on it. I then borrowed my friends hudy tool and it would not budge them either. So, I would not buy any tool if you are trying to remove the associated pins.
we use a vise that has a diamond shaped hole cut out, you put the pin in the hole and hammer the pin down. once its flush use a pin punch and countersink it a bit once its counter sunk you put the new pin in and hammer it til its centered. sounds complicated but it is really simple.
http://www.amazon.com/Palmgren-12303...1354539&sr=1-5
no matter what it takes hammering. The vise also has a lot of other uses. I wish I was ready to do mine again I would video it, it really is so simple 6 pins takes 10 minutes.
Last edited by jnslprd; 03-09-2012 at 09:13 PM. Reason: 3rd grade spelling and grammer
